- Joined
- 21 Aug 2008
- Messages
- 27
- Reaction score
- 0
- Country
Hi, I hope someone here can help as I'm currently tearing my hair out!
I had to turn off the hot water supply to refit a hot tap in the bathroom as the plastic nut had broken. Stupidly, rather than just turn off the mains at the internal stop-cock, I first tried closing the valves under the boiler. This didn't work so I turned off the mains, changed the nut and opened all the valves and turned the cold water back on.
The problem I have now is that the hot water pressure is much lower than before. Never had any problems with this previously but now only one hot tap works at a time and even that is low pressure. I've tried everything I can think of including making sure everything is fully open but no joy.
Any advice would be very much appreciated, thanks in advance!
