DIYnot
Local | Network
   DIYnot > Forums
Local | Network
No hot water coming thorugh mixer shower
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
SteveJ987
from United Kingdom
PostPosted: Fri Sep 05, 2008 10:48 am Reply with quote
I've recently (last month) had a new thermostatic mixer shower fitted - the manufacturer is Mayfair (product code SFL119). Its gravity fed, with hot water from the tank in the airing cupboard and cold from the cold water tank in the loft.
Its been fine until today but today there is no hot water coming through it -putting the temp to cold, the cold comes through fine but move it to hotter and it slows to a tiny trickle - i.e. theres no hot water being allowed to come through.
The water everywhere else in the house, including the bathroom where the shower is, is fine, both hot and cold - so the problem is isolated to the shower itself.
As it's brand new it seems more unlikely to be a problem with the valve itself - I'm wondering if it could be an air lock?
Would really appreciate any suggestions/ advice - many thanks!!
Back to top
 Alert Moderators
Technotim
from United Kingdom
Thanked: 18 times
PostPosted: Fri Sep 05, 2008 7:40 pm Reply with quote
I would be supprized if that shower works well off of gravity feed I would have assumed 0.5bar pressure required as a Minimum. The manufacturers site does not help with no specification details.
I would take the handset off of the hose lower the hose as much as poss then see if you can get a flow. if you leave it running for a couple of minutes if its air then it might do it, but not always.
If not take the valve off from the wall after turning off the supplies you can run off some water that way.
while it is off the wall check the inlet filters and non return valves if there are any.
Good luck.
Back to top
 Alert Moderators
SteveJ987
from United Kingdom
PostPosted: Sun Sep 07, 2008 9:36 am Reply with quote
Thanks Technotim - took the hose off and ran it through for a few minutes - must have been air as that sorted it - cheers
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
no hot water coming from bath shower mixer 10 740 Mon Apr 27, 2009 4:29 pm
Mixer Tap ( No water coming thru ) 3 220 Thu Nov 15, 2007 2:46 pm
No hot water coming from bath mixer taps 2 800 Tue Oct 23, 2007 9:33 pm
Water Coming very slowly through mixer taps 3 80 Fri Nov 09, 2012 7:57 am
No Hot water flow coming out of kitchen mixer tap 4 1040 Wed Jan 31, 2007 8:40 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
