DIYnot
Local | Network
   DIYnot > Forums
Local | Network
power consumption
Author Message
njkmr
from United Kingdom
Thanked: 1 time
PostPosted: Sun Sep 14, 2008 11:49 am Reply with quote
Hi All,
just a question about power consumption .Forgive me if I sound numb .
Anyhow here goes . 10 x 240 v 50 watt bulbs .Or 10 x 12v 50 watt bulbs on transformers .
Which one is more economical if any .I was thinking the low voltage ones would use less power but the fact they are both 50 watt bulbs is confusing me .
Can anybody advise as to whether the low voltage ones would use less of my hard earned cash to run.!
Many Thanks .
Regards
Rob.
Back to top
 Alert Moderators
davy_owen_88
from United Kingdom
Thanked: 1 time
PostPosted: Sun Sep 14, 2008 11:57 am Reply with quote
They are both the same, the only difference is in the amount of current used and therefore the size of cable required...
50 watts is 50 watts regardless of what voltage it takes...
50W / 230V = 0.22A
50W / 12V = 4.17A
4.17A x 12V = 50W
0.21A x 230V = 50W
As you can see 12v lamps draw significantly more current so the 10 lamps will draw nearly 42A between them, so you'll either need a hefty transformer and some huge cable or numerous transformers... Both of which bumps the price up.
Back to top
 Alert Moderators
njkmr
from United Kingdom
Thanked: 1 time
PostPosted: Sun Sep 14, 2008 11:59 am Reply with quote
Thanks for the speedy response .
Regards
Rob.
Looks like I will have to keep telling the kids to switch them off then .!!
Back to top
 Alert Moderators
davy_owen_88
from United Kingdom
Thanked: 1 time
PostPosted: Sun Sep 14, 2008 12:35 pm Reply with quote
Then buy a downlighter from this range: http://www.tlc-direct.co.uk/Main_Index/Lighting_Menu_Index/Lighting_Downlights_Index/Downlights_Energy_Saving/index.html
They use about 1/5th of the power and the lamps last about 7 times longer than normal GU10's.
Back to top
 Alert Moderators
njkmr
from United Kingdom
Thanked: 1 time
PostPosted: Sun Sep 14, 2008 2:03 pm Reply with quote
I should of looked on here before replacing them but never mind .
I do have them split so I can have 4 corner ones on only or 6 in the middle or all of them together .
At least I know for future reference .
Thanks Again .
Back to top
 Alert Moderators
kensplace
from United Kingdom
PostPosted: Mon Sep 15, 2008 3:59 am Reply with quote
Would the 12v lamps not end up using more electricity, as they would require a transformer, which will not be 100 percent efficient, so would waste electricity as 'heat' given off from the transformer, plus some wastage in the low voltage cabling (minute probably) as the voltage drop on a 12v cable is likely to be more problematic than on a 240v one.
The amount is small I would have thought, but the mains one should in theory I guess use a little less than a 12v one...
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1951 times
PostPosted: Mon Sep 15, 2008 8:12 am Reply with quote
Increased voltage drop will just mean less light for your money, not more money spent.
Basically if you're concerned about running costs don't use incandescent downlights at all - wondering if LV ones use more or less power then ELV ones is a bit like wondering if you should buy a Range Rover or a Land Cruiser because you're worried about fuel consumption....
Back to top
 Alert Moderators
sm1thson
from United Kingdom
PostPosted: Mon Sep 15, 2008 8:16 am Reply with quote
yeah but the 12v bulbs are driven at a higher current which is more efficient, but either way they all use a lot so slight differences between them are negligible.
Back to top
 Alert Moderators
njkmr
from United Kingdom
Thanked: 1 time
PostPosted: Mon Sep 15, 2008 6:13 pm Reply with quote
ban -all - sheds ,good reply .lol
like the comparison to range rover/ land cruiser ![/quote]
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Power consumption of double oven 18 3960 Tue Sep 15, 2009 8:56 am
Power consumption 2 300 Sun Sep 21, 2008 10:33 am
dimmer switches and power consumption 2 340 Sun Dec 07, 2008 8:34 pm
working out power consumption 3 1280 Sun Jan 07, 2007 11:44 pm
Power consumption striplight 5 880 Thu Mar 29, 2007 1:24 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
