wadge
Joined: 20 Dec 2006 Posts: 41 Location: United Kingdom Thanked: 2 times
Posted: Thu Sep 18, 2008 7:51 pm Post Subject: Finders - with drill bit sets |
I've bought a new box set of drill bits and driving bits. In it there are a couple of rounds plastic bits called finders? They are common with most of these type of box sets. What are they and how do I use them? |
xerxes
Joined: 13 Jan 2006 Posts: 970 Location: Bristol, United Kingdom Thanked: 0 times
Posted: Fri Sep 19, 2008 6:41 am Post Subject: |
New to me, but according to this they are devices for locating a bit in a slotted screw head.
I'm inclined to agree that this sounds like something one can do without. |
wadge
Posted: Fri Sep 19, 2008 8:53 am Post Subject: |
Thanks. Agreed, pretty redundant although I can see where the original need for it came from.
Sometimes slotted screws can be a pain in awkward or tight corners with a cordless driver. |
neds
Joined: 18 Nov 2007 Posts: 629 Location: United Kingdom Thanked: 0 times
disinfo
Joined: 07 Oct 2007 Posts: 872 Location: Yorkshire, United Kingdom Thanked: 5 times
mattylad
Joined: 26 Apr 2008 Posts: 2479 Location: Lancashire, United Kingdom Thanked: 9 times
Posted: Fri Sep 19, 2008 3:35 pm Post Subject: |
They also hold the screw while you start to screw it in.
I have several but never used them.
Slotted screws are dangerous when using a Electric driver, but IMO much better when using a hand screwdriver & needing a good "thrutching" !
That said as I'm now officially lazy & use the electric driver, I only ever use cross head unless on a door. |
noseall
Joined: 02 Feb 2006 Posts: 11053 Location: Staffordshire, United Kingdom Thanked: 71 times
Posted: Fri Sep 19, 2008 3:59 pm Post Subject: |
once painted a few times, cross head or posi are almost impossible to remove.
never have this problem with slotted.
no good for the cordless driver though.
ho hum.  |
xerxes
Posted: Fri Sep 19, 2008 9:02 pm Post Subject: |
Last year I had to remove a large number of slotted screws from a ceiling. The only sensible way to go about it was with a cordless driver, but it was a messy business. To make things worse, the heads were very hard (and brittle) so I had quite a few broken screws which had to be removed with pliers. Maybe a screwfinder would have come in handy for this job, if I'd known they existed.
I would still use slotted screws where they're going to be on display when the job's finished, installed with a screwdriver of course, and driven home so that the slots are aligned.
I also like to use slotted screws in a location where they're liable to get very dirty, or clogged with paint, and I might need to remove them later, for the reasons Noseall gives. |
