Hello chaps, I have small problem and I'm looking for a bit of advice..so here goes:
I am looking to change a window in my kitchen but when I took some tiles off the wall, I noticed there is no lintel installed in the wall. There is nothing above the kitchen as it is an extension to a ground floor.
I have been told that if I cut out a hole above the window opening (which is 90cm) about 1.5 metres long and install the lintel by concreting it in and holding it in place by the means of jacks this will solve the problem. There is a fine crack leading from the top of the window opening to the roof (which is flat).
Is this the right way to go or would you suggest anything different?
Thanks very much in advance!
