DIYnot
Local | Network
   DIYnot > Forums
Local | Network
BMW MINI-Air lock in radiator
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance
Author Message
2slow
from United Kingdom
PostPosted: Sun Nov 16, 2008 3:44 pm Reply with quote
My wifes' mini has an airlock in the system,the fan seemed to run loud and long after stopping, I asked her when she last topped the rad up ,she replied"Never have done" icon_cry.gif. Needless to say the top-up container was empty, I undone the valve/screw on the top hose and let out the bubbles and air until it seemed to leak just water,but the problem seems be re-occuring.Anyone know how to bleed the system as I obviously have not got it right?
Back to top
 Alert Moderators
ch427
from United Kingdom
Thanked: 233 times
PostPosted: Mon Nov 17, 2008 10:58 am Reply with quote
some are hard to shift,have you re checked the level once the engine has cooled?
a short road run and another bleed may help it but make sure you keep your eye on the temperature gauge
Back to top
 Alert Moderators
davieboy
from United Kingdom
Thanked: 12 times
PostPosted: Tue Nov 18, 2008 12:28 am Reply with quote
minis are usually a complete cow to remove an air lock. vacuum filling works every time. a garage job i'm afraid. have you removed the filling plug (10mm allen key) at the n/s/r of engine to fill??
Back to top
 Alert Moderators
CortinaV8
from United Kingdom
Thanked: 9 times
PostPosted: Tue Nov 18, 2008 1:51 pm Reply with quote
The mini's have a couple of bleed points, the ones mentioned above and a small 8/0mm bolt towards the front right hand corner of the engine, from what I remember you really need to remove the plastic tray that the injector wiring is attached to in order to get access to this one, careful when you put it back in, if you drop it, it will more than likely end up between the engine block and manifold!!!
Also might be worth checking the bottom corners of the radiators for leaks if it's losing water (common mini failing, metal rad crimped to plastic end tanks)
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance All times are GMT
Page 1 of 1
Jump to:
Need advice and help about my mini after a crash 3 120 Sun Jul 14, 2013 10:32 am
Mini (BMW) oil pressure sender unit? 8 260 Fri Sep 20, 2013 3:06 pm
This fell off my mini,what is it? 17 500 Thu Dec 12, 2013 6:39 pm
Mini cooper accident damage 14 280 Sat Jun 15, 2013 6:17 pm
Mini 3 480 Sat Mar 01, 2008 11:36 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
