DIYnot
Local | Network
   DIYnot > Forums
Local | Network
valley lay boards - what are they & how do i construct p
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering
Author Message
jema
from United Kingdom
PostPosted: Sun Nov 16, 2008 11:30 pm Reply with quote
existing room in roof, ex tiled pitchedroof specified by Struct eng. to join to new roof at a valley using layboards (no valley beam), no other structure under valley.
s.e. not around this week, cant find any pictures / diagrams in books or internet - havent a clue really what this looks / detailed-
please can someone point me in the right direction at some illustration / diagram so i can fathom out what i need to order ... and then do..
many thanks J.
Back to top
 Alert Moderators
^woody^
from United Kingdom
Thanked: 1255 times
PostPosted: Mon Nov 17, 2008 12:33 am Reply with quote
There are threads on this - one within the past 3/4 months with details and images
Back to top
 Alert Moderators
jema
from United Kingdom
PostPosted: Mon Nov 17, 2008 1:32 am Reply with quote
thanks,
i dont suppose you can remember the author / any details can you , i did search, the only thing i found was Aug08 a very brief description of 200 x 38mm wood - i couldnt figure it out from that
thanks J.
Back to top
 Alert Moderators
chappers
from United Kingdom
Thanked: 30 times
PostPosted: Mon Nov 17, 2008 7:06 am Reply with quote
there must be structure under the valley if you are using a layboard, as a layboard is a piece of timber that sits on the main roof rafters to give the diminishing rafters, of the intersecting roof, something to sit on.
To have no structue under the valley you would need to fix a valley blade, which is a more substantial piece of timber running the length of the valley supporting common rafters from both roofs
Back to top
 Alert Moderators
^woody^
from United Kingdom
Thanked: 1255 times
PostPosted: Mon Nov 17, 2008 10:51 am Reply with quote
I know that I posted in the threads.
If a search for valley does not come up with the threads, then use google to search this site, as google will normally find the parts that DIYnot does not reach
Back to top
 Alert Moderators
Deluks
from United Kingdom
Thanked: 326 times
PostPosted: Mon Nov 17, 2008 3:35 pm Reply with quote
Found this in 'similar topics' right at the bottom of this thread icon_idea.gif
http://www.diynot.com/forums/viewtopic.php?t=138953
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1293 times
PostPosted: Mon Nov 17, 2008 5:34 pm Reply with quote
as chappers said, a lay board simply 'collects' the diminishing rafter ends.
it must be wide enough so that the splayed cut rests entirely upon the lay board.
setting the lay board requires a little knowledge. you need to have the common rafters in place in order to 'range through' with a straight edge.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering All times are GMT
Page 1 of 1
Jump to:
Lean-to type vaulted ceiling/roof - how to construct one? 7 10760 Sun May 03, 2009 9:20 pm
valley / valley boards 8 6660 Tue Jun 17, 2008 8:22 pm
valley boards 2 580 Tue Aug 26, 2008 2:10 pm
fitting roof valley boards where different roof styles meet! 7 4020 Fri Apr 16, 2010 9:51 pm
Roofing work and valley boards 2 920 Mon Jan 26, 2009 11:58 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
