Guest
Thanked: 0 times
Posted: Wed May 15, 2002 10:13 pm Post Subject: electrics |
Hi -
I'm trying to wire a flex holder to a bulb as above - unfortunately, my flex has a blue, brown and yellow/green wire, but the bulbholder only has 2 screw terminals.
What am I supposed to do with the green/yellow wire in this instance.
Aparna |
Guest
Thanked: 0 times
Posted: Wed May 15, 2002 10:16 pm Post Subject: Re: electrics |
If the light shade is metallic then it should have an earth terminal, in which case connect it to this. If it is not metallic the green/yellow wire is not required to be connected to anything and can be left. |
