Acid power washing central heating system
15 Nov 2005
Birmingham
Got a Central Heating Company to check why I had no hot water/ boiler cutting out, but heating working fine
They said they checked boiler, system, 3 wy valve, thermostat and pump and everything works fine
They recommended "acid power wash of entire system" quoting about £800.00 because thought system probably "sludged up"
Is there a cheap additive I can add to system to help this?
What do you think of the acid power wash idea?
Is the boiler only cutting out when you are trying to heat the hot water only or does it also cut out when you have the central heating on?
If it was sludged up, the central heating would not work properly.
They said they checked boiler, system, 3 way valve, thermostat and pump and everything works fine
They would say that - they want you to spend £800.
Do you live in a hard water area?
If yes; how old is the hot water cylinder?
When you are calling for hot water only, is the pipe between the 3 way valve and the boiler warm?
Some simple system checks
Turn the power off (this resets the mid position valve)
Set your CH and HW timers to off.
Turn CH and HW thermostats down.
Turn power on (relight boiler if necessary)
Turn HW on at timer
Turn HW thermostat up to max.
The boiler should light and the pipe from 3 -way valve to HW cylinder get hot.
Check the return pipe from the HW cylinder is hot.
Turn CH on at timer
Turn CH stat up to max.
The boiler should continue to run.
You should hear the 3-way valve move to mid position (get help if necessary) and the pipe from 3-way valve to rad should get hot.
Turn the HW thermostat down.
The valve should move over to CH only position and the boiler continue to run.
Turn HW stat up to max so the valve returns to mid position
The boiler should stay alight and both pipes from 3-way valve get hot
Turn HW OFF at timer
The valve should go to CH only position.
Just the CH pipe from 3-way valve will be hot.
If the Return pipe from the HW cylinder is cold when the feed from the 3-port valve to the cylinder is hot, you have a blockage in the cylinder coil. But if it is hot, or slightly cooler than the feed, the coil in the cylinder is furred up so none of the heat is reaching the water.
Sludging of the system usual presents itself in the radiators firstly. When the heating is running are some of the bigger radiators stone cold in the centre at the bottom even if the heating has been on for while.
Sometimes the pipes in the system can fur up like your arteries reducing flow which can lead to certain radiators not working, or in some cases the hot water not circulating.
Hot water failing to circulate due to sludging I have only seen on systems that used to work on gravity.
Powerflushing should work in most cases of the above. Additives that the DIYer could use I would not recomend as they are either so weak as to not work in extreme cases or so strong that they could cause other problems if not used correctly. My advise would be to get a second opinion from recommended HE in your area.
AH
I just remembered going to look at a fully pumped system, with two zone valves, 100,000 BTU floorstanding boiler, and the airing cupboard directly above.
The homeowners said hot water had been working fine all summer, turned the heating on and shortly the hot water stopped heating. My boss didn't believe me that the hot water return was blocked. We cut out 2 metres floor to ceiling of vertical pipe that was totaly blocked!
AH
Like I said though, probably best to get someone else to look it over
