Circuit for 3 way Valve
24 Aug 2004
Devon
What circuit is the 3 way valve actuator in the airing cupboard likely to be on? I need to change one tonight, so I am hoping it's on the Ring Final sockets, not the lights! I have a voltage meter to check for dead when I start isolating.
But it's unlikely the heating will have it's own dedicated circuit at the CU? Are most heating controls spurred into the one of the final ring socket circuits? I was planning to isolate at the CU.
The Congo is in the tropics. Why the hell do you need to fit a frost stat there????
I'm beginning to think you are lying about your location.. ;)
My heating has its own dedicated circuit.
You'll have to find where it is fed from and isolate at that point.
The reason I said NOT to isolate by switching off the programmer is because you may have a frost stat taken direct from the live feed that overrides the programmer controls.
Most valves will have a permanent live to the microswitch for boiler/pump triggering. (Orange or grey, I can never remember which way round it's supposed to be without checking)
The central heating should also have it's own switch fused spur, regardless of whether it on a ring, dedicated circuit or otherwise.
