DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Replacing float valve for cold water storage tank
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Gaz Spurs
from United Kingdom
PostPosted: Mon Dec 22, 2008 1:26 pm Reply with quote
hello,
i need to change the float valve for my cold water tank, as it not functioning correctly.
the current valve is a part 1, am I right in thinking that I need to replace it with a part 2? I have seen versions marked high pressure and low pressure - I assume I need a high pressure one as it will be connected to the rising main?
also, can anyone offer some general tips for doing this? are there any great differences in connecting a part 1 and a part 2? the old valve is covered in scale and verdigris, and so I think it's going to be tough to remove it.
lastly, there is no way of isolating the tank without shutting off the water in the kitchen. Is it worthwhile adding an isolater for the tank? What would be the best choice? stop cock, ball valve, gate valve, etc?
Back to top
 Alert Moderators
Rico99
from United Kingdom
Thanked: 30 times
PostPosted: Mon Dec 22, 2008 1:33 pm Reply with quote
Gaz,
Yes you're right, you have to fit a part 2 valve.
They are eactly the same as a part 1, but the water comes from the top of the valve thru a plastic elbow instead from underneath. This creats an air gap to stop back flow.
As for isolation, get and angles service valve, this screws directly onto the back of the float valve and results in the least amount of adlust to the pipework.
[img]
[/img]
Rico
Back to top
 Alert Moderators
Gaz Spurs
from United Kingdom
PostPosted: Mon Dec 22, 2008 1:44 pm Reply with quote
Thanks Rico,
So, this is the right one:
http://www.screwfix.com/prods/11518/Plumbing/Toilet-Fittings/Float-Valve-Part-2
The angled service valve has confused me. Are you assuming that the rising main comes up along side the tank, then angles 90 degrees just as it goes into the tank? Mine actually comes up into the loft on the other side from the tank, but comes up to its full height there, then runs across the loft and runs straight into the tank. icon_rolleyes.gif
Back to top
 Alert Moderators
Rico99
from United Kingdom
Thanked: 30 times
PostPosted: Mon Dec 22, 2008 1:48 pm Reply with quote
Gaz,
Yes that the right float valve.
As for the service valve, yes assumption made on my part.
Use this one instead.
Rico
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1245 times
PostPosted: Mon Dec 22, 2008 1:49 pm Reply with quote
use a straight service valve then not an angled one
Back to top
 Alert Moderators
Gaz Spurs
from United Kingdom
PostPosted: Mon Dec 22, 2008 1:53 pm Reply with quote
icon_lol.gif some things are so obvious with the benefit of hindsight...
thanks guys
Back to top
 Alert Moderators
Rico99
from United Kingdom
Thanked: 30 times
No Schwet Gaz,
Let us know how you get on.
Rico
Back to top
 Alert Moderators
steved101
from United Kingdom
Thanked: 3 times
PostPosted: Mon Dec 22, 2008 4:53 pm Reply with quote
tap connectors, like the 1 in the pic above, with built in isolation/service valves are much better than fitting separate!!!
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Replacing a noisy float valve in tank 4 580 Tue May 12, 2009 8:47 am
changing float valve in cold water tank - and pipe freezing! 23 7160 Wed May 28, 2008 3:06 pm
Cold Water Tank Float Valve Problem PLEASE HELP! 4 80 Tue Sep 17, 2013 7:29 pm
Repalcing Cold water Tank Float Valve 7 840 Tue Jul 17, 2012 10:38 pm
Water hammer noise with cold tank float valve issue 6 120 Mon Sep 15, 2014 3:22 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
