DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Ideal Mini S24 not firing/lighting up
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
gaztaylor
from United Kingdom
PostPosted: Tue Dec 23, 2008 7:47 am Reply with quote
I've got a problem with my Ideal Mini S24 Boiler not firing/lighting up and of course I've got no hot water or heating. I've repressurized the system so it's now just under 1.5 Bar (it was on less than 0.5) and there is power going to the unit (flashing light every four seconds). But whenever I turn the main switch to on I get lots of flashing lights per second and it sounds like the boiler is trying to light but failing. I don't think it's a power issue as the unit seems to have power (the light) and we have gas as the cooker hob lights. Is this something I can fix myself or will I need a plumber/British Gas?
Back to top
 Alert Moderators
weargas
from United Kingdom
Thanked: 14 times
PostPosted: Tue Dec 23, 2008 7:59 am Reply with quote
You can certainly find out what's wrong yourself. It'll involve taking off the front panel and undoing the 4 screws underneath so you can pull the electrical controls forward. I personally remove the side panels so the control box drops down comfortably.
Next you undo the 3 screws and remove the small panel on the left hand top of the controls box (careful there's 240v ac in there). You then need to get the boiler into the fault state i.e. the green light flashing quickly. You then look inside the control box and you'll see a bank of 4 dip switches (and 2 more lights that can't be seen from outside). Flick the left hand dip switch one way then back again. This should've started the 3 lights flashing in a sequence. If you look in your manufacturers instructions it'll tell you what each sequence of lights (on, off, flashing) means. If you haven't got the MI post what's flashing on here.
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 803 times
PostPosted: Tue Dec 23, 2008 8:30 am Reply with quote
Sounds like the ch thermistor to me.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3565 times
PostPosted: Tue Dec 23, 2008 11:20 am Reply with quote
The fact that you repressurised the boiler implies that you had let the pressure fall to zero.
You may need to spin the pump. However that will be identified by the fault code or you could just do it !
Tony
Back to top
 Alert Moderators
shambolic
from United Kingdom
Thanked: 580 times
PostPosted: Tue Dec 23, 2008 4:54 pm Reply with quote
depends on model as new boiler has single pcb and no dipswitches. The flashing three light sequence will still tell you fault.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3565 times
PostPosted: Wed Dec 24, 2008 1:38 am Reply with quote
The single PCB on the non condensing boilers STILL have the DIPs !
Tony
Back to top
 Alert Moderators
shambolic
from United Kingdom
Thanked: 580 times
PostPosted: Wed Dec 24, 2008 6:59 pm Reply with quote
174469 for he and 174500 for se look identical no dipswitches done through turning potentiometers to set up etc. You can see the three lights in fault mode as soon as it faults. No dipswitches!!!!!!!!
I have both pcbs in van. Have had problems with several engineers fitting he version to se boilers. It melts the gv solenoid!
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3565 times
PostPosted: Wed Dec 24, 2008 7:19 pm Reply with quote
I am a little confused by what you are telling me. Have you looked at it today?
I have the Biasi boxed version by me which is BI 885101 and that does have DIP switches!
Have you really looked at one of your spare parts?
I note that the Ideal book shows the DIP switches in the picture on page 38 and they seem to call the single PCB model an S24/28
Tony
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Mini C28 Lighting then shutting off 6 120 Sat Jun 04, 2011 12:00 pm
Main Combi 25 eco not firing/lighting (heating and hotwater) 13 120 Thu Jan 09, 2014 12:13 pm
re firing/lighting boiler 3 80 Wed Apr 17, 2013 7:27 pm
Potterton 100e continually firing but not lighting 6 620 Thu Aug 09, 2007 7:00 pm
Lighting the pilot on a c95ff ideal combi boiler 2 400 Sat Jan 03, 2009 12:33 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
