DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Back fall on soil pipe
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Adrian80
from United Kingdom
Thanked: 6 times
PostPosted: Tue Jan 06, 2009 9:33 am Reply with quote
Hi i was wondering if this is going to cause me a real headache in the future,
the soil pipe as it exits the wall, on the right hands side of the toilet, has a very small back fall, the spirit levels bubble is not quite center and if i lift the level about 1mm over half a metre, it becomes bang on.
I think when i cored the hole i didnt get it absolutely spot on.
i have put the toilet in and chucked a bucket of water down it, no leaks and the water in the toilet is at about the right level. However when i dismantled the pan connector a little bit of water came out.
Do you think this is going to drip or have a rubbish flush.
or am i worrying over nothing.
i think i have three options.
1. Do nothing.
2. Chip out the hole so the fall is right.
3. cut the pipe off flush to the wall put an extension in, then the back fall is only as long as the wall is deep, plus as the extension goes into the soil pipe it should be even less, than the depth of the wall, but then i have two potential joints opposed to the one.
all advice greatly appreciated
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 982 times
PostPosted: Tue Jan 06, 2009 10:07 am Reply with quote
A back fall is never a good idea &, in fact, does not comply with B Regs. You will undoubtedly get standing water & a potential for other “goodies” to lie in that section of the pipe which could lead to a blockage. You have easy access to clear, it’s very close to the w/c & if the section of pipe is fairly short, in reality, it’s likely to be self purging. If it’s a lot of hassle to rectify, I would be inclined to leave it but if it’s a new w/c install & subject to inspection, the BI may pick it up & ask you to fix it.
Fall should be 18mm/metre minimum.
Back to top
 Alert Moderators
Adrian80
from United Kingdom
Thanked: 6 times
PostPosted: Tue Jan 06, 2009 10:57 am Reply with quote
Thanks rich,
i will get the hammer and chisel out this evening, and see if i can get the bubble to rock the other way.
cheers for the advice.
Adrian
Back to top
 Alert Moderators
Adrian80
from United Kingdom
Thanked: 6 times
PostPosted: Wed Jan 07, 2009 10:43 am Reply with quote
I came to the conclusion that the soil pipe was PVC, and being a thermoplastic it was dead easy to warm it up and bend it so the fall is going the right way.
sorted no joins no leaks.
happy days..
A
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
soil pipe fall quick question 5 1360 Thu Oct 14, 2010 1:33 pm
What fall do I need on a soil pipe from a toilet? 2 640 Mon Feb 13, 2006 8:09 am
Rainwater fall pipe and soil stack 4 100 Wed Apr 11, 2012 7:10 pm
Soil Pipe Fall - advice please 8 760 Fri Nov 06, 2009 7:35 pm
Bath Waste Pipe Fall 3 140 Thu Jul 19, 2012 1:10 pm
DIYnot
