DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
power socketss
This topic originated from the How to page called Routing cable
Click here to return to the page called Routing cable.
  View previous topic :: View next topic
Author Message
ruffy
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 11, 2004 5:05 pm    Post Subject:
power socketss
Reply with quote Thanks
i want to lower the sockets in the kitchen. but to not have enough wire what is the best way to extend to wiring
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
andy
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 11, 2004 5:42 pm    Post Subject:
make a spur from the original socket
Back to top
 Alert Moderators
ruffy
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 11, 2004 5:52 pm    Post Subject:
thanks i want to remove the old sockets to install the new ones the new sockets are going to be aprox 4 inches lower hence the shortage in wire
Back to top
 Alert Moderators
andy
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 11, 2004 6:12 pm    Post Subject:
make the cables longer by crimping them and not a terminal block (if usin a terminal block then it must be accessable)
Back to top
 Alert Moderators
ryanj
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 11, 2004 6:13 pm    Post Subject:
Are the sockets on the ring or are they spurs? (How many cables are there?)
It'd obviously be best to replace the whole cable, but if thats not practiable, you can use crimped connnectors, within a suitable enclosure, hidden in the wall, or in the existing box with a blanking plate.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Thu Nov 11, 2004 8:14 pm    Post Subject:
Re: power socketss
The best way is to buy more cable and replace the short ones entirely.
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
ruffy
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 11, 2004 9:15 pm    Post Subject:
Re: power socketss
what are the dangers in using terminal blocks
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Thu Nov 11, 2004 9:34 pm    Post Subject:
There is a danger that the connections could work loose, but then all sockets and switches etc use screw terminals, so it's probably not a significant danger.
The real problem is that such joints must be accessible, so having made them, you'd have to just cover up the old socket boxes with blanking plates - you would not be allowed to permanently cover up the joints, e.g. by plastering or tiling, whereas with crimped connections you could.
BTW - if you crimp, you must use a proper ratchet crimper, not one of the cheapo squeeze'n'hope ones.
__________________
Back to top
 Alert Moderators
Damocles
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 11, 2004 10:18 pm    Post Subject:
If you really covered it up, no one would know it was there so they would never object that it was a violation of regulations.
The real problem is the first one. That some day you may need to get at the terminals again. Also possibly, if you change direction at the junction, then the wall cables may no longer be in a 'safe' area immediately above or beside a visible fitting.
It is true however that a whole cable is better protected than a joined one. It is not possible for water to get inside a whole cable. Perhaps not very relevant half way up a wall, but might be if it was under the bathroom floor, under the washing machine, or anywhere downsatirs if you live in a flood area.
__________________
His vorpal blade went snicker-snack
Back to top
 Alert Moderators
ruffy
from United Kingdom
Thanked: 0 times
PostPosted: Fri Nov 12, 2004 11:58 am    Post Subject:
thanks to all of you i am going to crimp the wires ind plaster over them so i can start tiling that im looking forward to. not
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Sat Nov 13, 2004 2:20 am    Post Subject:
squeeze'n'hope.
The story of my life as a teenager, Ban!!
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Moving a Power Socket 8 420 Fri Feb 15, 2008 11:09 pm
fittin power out side 3 140 Sun Feb 17, 2008 1:48 pm
Drilled through socket power cable!!!! 13 700 Fri Feb 15, 2008 10:02 pm
power supply to garden shed 7 1840 Thu Feb 14, 2008 10:20 pm
Moving power sockets 17 740 Tue Feb 05, 2008 12:21 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
