DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Electric Oven
This topic originated from the How to page called Installing a cooker hood
Click here to return to the page called Installing a cooker hood.
  View previous topic :: View next topic
Author Message
rglister
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 13, 2004 2:44 pm    Post Subject:
Electric Oven
Reply with quote Thanks
If I install a separate SPUR for a fitted electric cooker, does it need an FCU in the kitchen?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat Nov 13, 2004 4:04 pm    Post Subject:
an electric cooker requires its own circuit and cooker connection unit, also 6mm cable which wont fit / too much for an fcu
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Sat Nov 13, 2004 4:33 pm    Post Subject:
Possibly even 10mm˛ cable....
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
fred hiscock
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 07, 2005 11:33 am    Post Subject:
Re: Electric Oven
I am fitting an electric hob and oven. I am providing a 6mm spur to each direct from the consumer unit. I have a suppliers spec (20 amp oven 30 amp for the hob) for the switches / breakers at either end of the cables. My question is how long can I make each spur. I guess I would like them about 25 metres linear each. Is this ok. How much further could I take them if necessary? Regards Fred
Back to top
 Alert Moderators
JayS
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 07, 2005 2:10 pm    Post Subject:
rglister's title says oven...topic says cooker...
If it's a built in oven consider the following. What's the rating of the oven? If it's less then 3kW it'll do nicely in a 13A socket. icon_smile.gif
Assuming this is the case and that you are running a spur off the ring main I think a 13A FCU is to be recommended but it's not a requirement I believe.
If it's a cooker as breezer says.
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 22 times
PostPosted: Mon Nov 07, 2005 5:59 pm    Post Subject:
no it wont fall under part p, work started in nov04
Back to top
 Alert Moderators
Gary0
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 07, 2005 6:49 pm    Post Subject:
Umm ... just intrigued. So it's when the work started that's important for Part P ? Not when it finishes ? (Please, yes/no if possible, rather than link to part P, would be much appreciated. Thanks)
__________________
I may take 10 times as long, but all the decent professionals are too busy to look and estimate.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
Re: Electric Oven
JayS wrote:
Ah - but was he replying to the latest addition?
Those aren't spurs, they are circuits, and notifiable to LABC.
http://www.tlc-direct.co.uk/Technical/Charts/VoltageDrop.html
Also, you need to read, and come to understand this: http://www.tlc-direct.co.uk/Book/4.3.1.htm so that you can show LABC that you've done it properly. You'll also need to acquire the necessary test equipment.
No, but seriously - if you do plan to comply with the law, you will need to do it competently, even with a cooperative LABC who do what they are supposed to. If you've got one of the stroppy ones, you'll need to be on very firm ground if you are going to argue with them....
__________________
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Mon Nov 07, 2005 6:57 pm    Post Subject:
For electrical only work, it used to be, but that window has now closed. (April 05).
For general buildng work, the issue of whether or not compliance with Part P has to be added in can be determined from this:
__________________
Back to top
 Alert Moderators
Gary0
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 07, 2005 8:06 pm    Post Subject:
Ah, thanks. Thought that sounded to good a loophole to have been overlooked icon_smile.gif
__________________
Back to top
 Alert Moderators
JayS
from United Kingdom
Thanked: 0 times
PostPosted: Tue Nov 08, 2005 10:16 am    Post Subject:
Yes, you were able to start work before 1st of January 2005 and finish it before the 1st of April without having to bother with part P...but if it's not finished yet then it falls under part P...
ban-all-sheds, any circuits going into a kitchen would also be effected (as well as being notifiable to LABC) by part P I presume since they would be a fixed installation?
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue Nov 08, 2005 10:35 am    Post Subject:
Yup.
__________________
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Electric oven & hob 5 3840 Fri Jan 06, 2006 3:38 pm
Another Gas Hob & Electric Oven question... 3 3380 Thu Nov 18, 2004 5:26 pm
Installing an electric oven 6 820 Sat Jan 07, 2006 1:55 am
electric build-in oven + gas hob ignition connection 4 6160 Wed Nov 03, 2004 10:48 am
Electric oven and hob wiring 5 860 Sat Sep 09, 2006 9:30 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
