rocks1
Joined: 30 Apr 2008 Posts: 5392 Location: Turkey Thanked: 880 times
Posted: Wed Jan 14, 2009 3:53 pm |
Indesit WIDL Codes
See also Hotpoint WF & some WD, left hand lights from top to bottom or digital display.(next page)
widl codes - light flashing from left to right are numbers 1-4
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
f1 and f17 share the same light
PeterBill
Joined: 14 Jan 2009 Posts: 6 Location: Aberdeen, United Kingdom
Posted: Thu Jan 15, 2009 8:49 am |
Hi Rocks,
I have an older machine, Indesit wi101, which does not have all the lights and no Fxx read out.
It has a control knob which now clicks round and a single led light which flashes - this indicates the problem - mine flashes once and pauses for about 10 seconds then flashes once again ....
Wondered if you had the error code for the flashing light?
Pete |
rocks1
Posted: Thu Jan 15, 2009 2:29 pm |
its the same as the codes but no light ,refit the connections on pcb make sure they are tight if not pcb is shot |
holmwoc
Joined: 09 Feb 2011 Posts: 3 Location: Plymouth, United Kingdom
Posted: Thu Feb 10, 2011 8:18 pm |
so i have looked at your list of error codes, and as my ariston led flashing are 1 and 4.
going by your info ii think mine may be the eprom/set up error?
can you advise what this means please
regards |
rocks1
Posted: Thu Feb 10, 2011 8:25 pm |
Explained in your other post. |
