Hi all,
I am replacing the light switch in our dining room. Unfortunately, I didn't mark the wires in the old switch properly before I removed it.
So....
The switch controls both the dining room light and lounge light. However, it seems it also has feeds for several other lights on the same floor (cloakroom, hall, outside light).
The cables coming into the switch are as follows :
1x 3 core and earth (brown, black, gray, earth)
4x twin core and earth (brown, blue ,earth)
Both the existing switch and new one have two sets or terminals (L1,L2 and L3). The old switch had the 3 core and earth cable connected as follows, o I've duplicated that one one side of the new switch
Gray to L3
Black to L1
Brown to L2
All of the blue cables are connected together in a choc block so that's not a problem.
So, I'm left with 4 x brown wires and a further wire that in the old switch joined L1 on one side of the switch to L2 on the other.
After having a go myself and ALMOST getting it working (i.e. the lights would only work when another light was switched on etc), I've had a handyman in and he couldn't get it right either, although he does seem to have identified each brown feed and labelled them.
Help please !
So....
Gray to L3
Black to L1
Brown to L2
Help please !
