In my dining room I have one light that is controlled by two switches, however I want to replace the two switches for dimmer switches. Is it possible to run one light off two dimmer switches with both dimmers fully working? Any advice would be greatly appreciated.
I've read though that these are not the most reliable of products, so you might want to seek out a better one. The sheds will probably be useless - try a proper lighting shop.
Thanks for the reply, i'm having a look at the weblink you posted. As an alternative idea, could I have one ordinary light switch and one dimmer switch controlling one light?
Ok, so I have a dimmer switch with a L1 & a L2 plus a common, and an ordinary switch with the same. So is this all I need to run one light with a dimmer, and an on/off switch?
