DIYnot
Local | Network
   DIYnot > Forums
Local | Network
HELP REPLACING A CEILING BATTEN HOLDER
Author Message
ifor
from United Kingdom
PostPosted: Sat Jan 24, 2009 9:27 pm Reply with quote
I have to replace an existing batten holder type ceiling fitting as the lamp holder crumbled away whilst changing a bulb ! got a similar holder hoping to replicate the connections . undid the original existing batten holder to find that it has different connections (there are three connections directly on the lamp holder) ! the original one has four cables coming in with each having a red and a black wire. all the reds are twisted together and connected on one terminal . three black cables are twisted and connected on a second terminal and one black wire is connected on the third terminal.
The new holder has a base plate with terminals marked loop, n and l and earth -- so the question is how do i make the connections ?
any advice greatfully received
thank you
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 1040 times
PostPosted: Sat Jan 24, 2009 9:53 pm Reply with quote
Were there definatly THREE blacks twisted together on your existing fitting?
Could you recheck this? I would normally expect there to be two black wires together.
Back to top
 Alert Moderators
david_uk
from United Kingdom
PostPosted: Sat Jan 24, 2009 10:20 pm Reply with quote
OP stated 4 cables. Therefore 3 neutrals and one switched return.
OP - put the three blacks that were twisted together in the neutral bar - the blue of the lampholder may already be connected to it. Its the bar with three holes on one end. The four reds to the centre "Loop" terminal (again, has three holes) and the one solitary black to the live connection to the lamp. That will be the end bar with 2 holes.
Obviously ensure the circuit is dead before you work on it.
Back to top
 Alert Moderators
ifor
from United Kingdom
PostPosted: Mon Jan 26, 2009 8:15 pm Reply with quote
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Wiring a Mount Batten/Lamp Holder 3 120 Wed May 11, 2011 1:09 pm
Batten lamp holder ... are all makes the same quality-wise ? 4 120 Mon Mar 24, 2014 12:04 pm
Changing Batten LaMp Holder 5 240 Sat Dec 20, 2014 12:02 pm
loft batten holder connection 5 400 Fri Mar 18, 2011 4:18 pm
Batten lamp holder - enclosure or direct to plaster? 11 160 Tue Dec 10, 2013 11:38 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
