I have to replace ferroli 77ff with new combi .
25 Jan 2009
Cardiff
Hello i need help . Don't know which boiler is similar to ferroli 77 ff can be a bit bigger.How many kw must be 24 or more i can't find on ferroli Thank you in advance
spend some time on properly explaining what exactly you want to find out; can't make heads or tails out of it
Why not ask your CORGI registered installer?
Tony
it has a heat input of 27Kw
Dhw flow rate of 8l/m @ 40*c temp rise.
why do you need to replace it?
This combi boiler is 15 years old. Many problems , defects. I think it's a good time to replace it. I found this boiler ; Biasi Garda HE 28 Kw in B&Q cost &549. Is it any good
If you want a Biasi I'd recomend you buy two so you got spairs at hand :)
what part of cardiff are you in? I live 10 mile out side cardiff.
