Vaillant Boiler problems
4 Feb 2009
Hampshire
Hi All,
We have a Vaillant boiler which has recently been moved by a corgi registered plumber. Unfortunately two problems seem to have developed. The first sounds like something is hammering inside the boiler and the second is when we turn the cold water tap on, the boiler starts up which doesn't seem correct and didn't happen before it was moved. Any ideas folks?
Many Thanks, Andy
A combination of water hammer and dead legs. A google for both of those terms should answer your problems. Get your man back.
Which model is it? A non return valve on the cold mains supply to the boiler may help with the nuisance operation as will setting d88 to 1 if you have an ecotec. You definately have a dead leg of water somewhere that needs capping and removing.
Many Thanks for your replies. I have noticed that the pressure drops over a period of about a month so there is a leak somewhere I guess. Would a "dead leg" be a pipe left after removing a radiator since that has not been done since the boiler was moved (due to removal of an internal wall). It is an Ecotek boiler by the way.
The hammtering seems more like a noisy humming if that makes sense, but it could it perhaps be due to air in the system?
What is d88? I understand the idea of the non-return valve though thanks.
Kind Regards
Andy
