machine leaks from soap draw
20 Nov 2004
My washing machine is a front loading bosch and recently it has started to leak quite a lot of water from out of the soap drawer part way through the cycle. I don\\\'t use the soap drawer as I add the detergent to a small bowl which I put directly in the drum. I\\\'ve cleaned the soap drawer out but the water seems to be siphoning back out of the machine. Can anyone suggest what\\\'s causing the problem and how I can fix it?
is it a washer / dryer and WHEN does the water come back out?
No its not a washer dryer. I'm not quite sure in which part of the cyle its leaking, I'll watch next time!!!!!!!! What a way to spend a Sunday!
