Hello
After reading numerous threads im none the wiser, so wondered if someone could help me. We are upgrading the electric oven and putting in an electric hob also.
At present theres only the one very thick wire coming from the the MCB to the cooker switch unit which has a built in plug outlet.
Now, how to I go about working out if I can run them both from the one wire or plug one in etc.
As you can probably tell Im not particularly in the know would liek some guidance, the oven says standard enegry comsumption 1.10KW
Not sure how to how to work out the energy consumption of the hob as it has numerous readings
