DIYnot
Local | Network
   DIYnot > Forums
Local | Network
wallpapering around chimney breast
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
Author Message
carl27
from United Kingdom
PostPosted: Sat Feb 21, 2009 4:21 pm Reply with quote
whats the best way to wallpaper around a chimney breast so it has 2 external corners to go around then 2 internal corners to go around to carry onto the wall. any pictures would be great . i have been told to bring it around the corner about 1 inch then plumb then rest of the paper up and over lap the 1 inch around the corner if the wall is not straight is this correct the only problem i am thinking with this is the pattern may be out and you will have a overlap joint which will not look good i dont think?
thanks carl
Back to top
 Alert Moderators
confidentincompetent
from United Kingdom
Thanked: 1 time
PostPosted: Sun Feb 22, 2009 12:50 am Reply with quote
I usually try to set out so the ends of the breast will go round at least 4". If not square you'll have to splice with knife in the recess. The next drop in the recess can be overlapped but do a double cut joint. i.e match the next joint over the 4"carefully so the top part of paper is in same position as the 4" bit then with a strait edge knife down both papers at same time (about 3" into recess) take away the loose bits and you'll have a perfect join. Well not to you but most peeps wont notice.
good luck
Back to top
The following user says thank you to confidentincompetent for this useful post:
omeg3i (13 Jun 2011)
 Alert Moderators
omeg3i
from United Kingdom
PostPosted: Mon Jun 13, 2011 1:13 pm Reply with quote
hello
I don't understand the above post (feeling very thick today), basically same thing, decorating chimney breast, which takes three strips across then I am left with about two milimeters gap at each side to go around the external corners with, its just not going to lie flat.
any help thanks
Back to top
 Alert Moderators
misterhelpful
from United Kingdom
Thanked: 360 times
PostPosted: Mon Jun 13, 2011 2:11 pm Reply with quote
Trying to get a few mm of paper to stick around an external corner is very rarely successful.
The easiest way, if your chimney breast is only a few mm over the width of 3 sheets of paper, would be to start with a join in the centre of the breast so that you effectively have 2 full width sheets on the wall and at each side of them the next sheet will wrap around the corner.
You should then have just under half of a sheet on each side wall of the chimney which you can either match to, or, as you say the corners are out of square, may need to overlap slightly. If you do need to overlap, you can slice through both layers of the paper which will allow you to remove the excess and leave a flat join rather than the ridge a standard overlap will give.
As confidentincompetent suggests, there may be a slight mismatch in the pattern, but other than yourself, most people will never notice.
Back to top
The following user says thank you to misterhelpful for this useful post:
 Alert Moderators
TheDec
from United Kingdom
Thanked: 373 times
PostPosted: Mon Jun 13, 2011 3:05 pm Reply with quote
Well that is certainly the way to overcome your problem, just remember though that half s sheet is a large amount wallpaper to turn around an external angle so take care not to crease the wallpaper,
Dec
Back to top
 Alert Moderators
omeg3i
from United Kingdom
PostPosted: Tue Jun 14, 2011 2:02 pm Reply with quote
thanks guys, I see now, just praying that the pattern is the same if I get into difficulties around the corners will probably be back on here to ask. not started it yet as I have some of the other bits to finish. icon_biggrin.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
Wallpapering external corner (chimney breast) 6 760 Fri Jul 12, 2013 9:11 am
Wallpapering a chimney breast, but fireplace isn't central. 7 160 Thu Jul 14, 2011 8:01 am
Holes appearing in old chimney breast brickwork. 4 280 Thu Jul 15, 2010 3:33 pm
chimney breast decoration 2 160 Fri Apr 22, 2011 9:16 pm
Hanging lining paper on chimney breast 3 660 Fri Apr 23, 2010 9:25 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
