| Author |
Message |
Mike-H
Joined: 20 Mar 2007 Posts: 84 Location: Warwickshire, United Kingdom
Posted: Wed Feb 25, 2009 9:31 am |
When I flush the toilet there is a loud groaning noise. It sometimes sounds like a steam boat has pulled into the bathroom  If I turn the sink cold tap on after flushing the sound increases.
I’m sure it is something easily fixed but I can not see what is causing the problem.
Thanks, Mike. |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
landyandy
Joined: 02 Nov 2008 Posts: 627 Location: Cheshire, United Kingdom Thanked: 60 times
Posted: Wed Feb 25, 2009 11:11 am |
Hi Mike.
It's probably caused by an old diaphram washer in your valve, vibrating just as the valve closes.
Turn the water off.
Strip down valve, taking note how to reassemble.
Replace diaphram washer (usually a round black disc).
Reassemble.
Simples.
Andy. |
| Back to top |
JohnD
Joined: 15 Nov 2005 Posts: 34364 Location: Hampshire, United Kingdom Thanked: 1088 times
Posted: Wed Feb 25, 2009 3:01 pm |
or fit a new valve which you may find quicker and easier
Later, you can repair the old one at your leisure on the kitchen table, as a spare, if you want, but they are not expensive. |
| Back to top |
Mike-H
| Back to top |
John506
Joined: 14 Nov 2006 Posts: 1337 Location: Merseyside, United Kingdom Thanked: 68 times
Posted: Thu Feb 26, 2009 3:14 pm |
| Mike-H wrote: | Thanks for the advice. Sounds like I need to do some graft then.  |
Yup about 5 mins work, such a graft  |
| Back to top |
Mike-H
Posted: Thu Feb 26, 2009 3:16 pm |
Are all valves the same? |
| Back to top |
Mike-H
Posted: Thu Feb 26, 2009 3:18 pm |
| John506 wrote: | | Mike-H wrote: | Thanks for the advice. Sounds like I need to do some graft then.  |
So i'm lazy, shoot me plus I will need to take the damn thing out find a replacement and refit. Now if i only lived near the local plumbing merchant life would be so much easier.  |
| Back to top |
seco services
Joined: 03 Dec 2007 Posts: 15466 Location: Essex, United Kingdom Thanked: 1215 times
Posted: Thu Feb 26, 2009 3:20 pm |
some are set height.
some are adjustable.
some have a ball.
some don't.
what have you got now ? |
| Back to top |
Mike-H
Posted: Thu Feb 26, 2009 3:24 pm |
| Back to top |
seco services
Posted: Thu Feb 26, 2009 3:31 pm |
| Back to top |
Mike-H
Posted: Thu Feb 26, 2009 3:34 pm |
Do they work with ball cistern? They do not have the arm that I would expect to see. |
| Back to top |
seco services
Posted: Thu Feb 26, 2009 3:38 pm |
no they don't have a ball they have their own float.
fit any cistern.
more chance of fitting them than the ball type as the ball needs more room for ball/arm. |
| Back to top |
Mike-H
Posted: Thu Feb 26, 2009 3:51 pm |
so that one part replaces the valve, arm and ball? It should fit into the existing space and magically shuts knows to stop filling the cistern.
Crickey, whatever next, lights that work at the flick of a switch? |
| Back to top |
seco services
Posted: Thu Feb 26, 2009 3:54 pm |
| Back to top |
Mike-H
Posted: Thu Feb 26, 2009 4:04 pm |
You cheeky scamp. They look like affiliate links. I may not know diy but I know websites
Thanks for the info. I used your links, but I will probably drop by the store on route home and pick one up.
Cheers,
Mike. |
| Back to top |
