- Joined
- 30 Sep 2004
- Messages
- 126
- Reaction score
- 1
- Country
We recently had the upstairs rewired and I am now fitting new lights. I had a bit of a shock (not literally thankfully) last night though and am puzzled as to what could be going on.
I'd turned the upstairs lights off at the CU and undid the ceiling rose. I checked the voltage between each of the 3 terminal blocks and earth to be sure and they were all 0 V.
I then started to remove the wires from the rose. However, the first one sparked as it came out and the light came on, dimly, but enough to scare me to death.
I measured various voltages between the terminal blocks and earth and these ranged from 230V, to 53V, but kept varying. I noticed some of the other upstairs lights also glowing dimly and the hall lights (that are on a different circuit that I hadn't turned off) were flickering but still fairly bright. Reconnecting the wire I had removed put things back to normal with the upstairs lights off and 0V on all the terminals, the hall light stopped flickering and was full on.
I removed the wire again and same thing happened. I turned the hall light off and the strange effects stopped.
Does anyone have an idea what might be happening. I remember when they came to do the re-wire at first they complained it wasn't straightforward as various upstairs and downstairs circuits were seemingly connected.
The rose in question had the following wires connected:
Neutral block: One old style black wire (this is the wire I disconected). One new style blue cable wire. One blue flex to the lamp.
Common block: Two old style red wires, one new style brown wire.
Live block: One old style black wire. One brown flex to the lamp.
What I am guessing is that the neutral from the hall light circuit is connected to the neutral from the upstairs circuit, but I can't understand how a current flows in the upstairs lamps as the live cable is switched off at the CU.
Either way I'm a bit unhappy that when I turn off at the CU, the lights suddenly come half alive when I disconnect a neutral wire.
Advice appreciated.
Advice appreciated.
