DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Blocked Macerator Outflow pipe(edited!)
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Giblets46
from United Kingdom
PostPosted: Wed Mar 11, 2009 8:38 am Reply with quote
Edit: Just found out, after dismantling the Macerator, thinking it was solely a fuse that had gone, that it seems to be pumping fine, and it is the outflow pipe that seems to be blocked, it was clearly stopping pumping with the heat trip switch))
So how can I unblock the outflow pipe? It would appear the plumber put on tight elbow bends on copper pipping, these clearly go up a couple of feet?
End of edit
Just found out my new place has a macerator in the bathroom! It previously made no noise, but recently has been making 'grumbles' (originally, being unaware we had a macerator, thought it was air in the pipes, as came along with showering).
Today it has stopped enitrely, and blocked up shower, sink etc.
Just wondering if there could be any other way of checking it it is just a simple blockage (in which case some easy means of unblocking), or a fatal error.
It is likely that things that should not be put down the loo have been (i.e sanitary ware etc), as we were not aware of the macerator.
Back to top
 Alert Moderators
kevindgas
from United Kingdom
Thanked: 467 times
PostPosted: Wed Mar 11, 2009 10:04 am Reply with quote
the only way is to remove it, clean out the !!!!!! with a large screwriver or stick, wash out & refit
if it works again happy days if it don't buy a new 1
DO NOT PUT YOUR FINGERS IN IT blades are lethal!
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3490 times
PostPosted: Wed Mar 11, 2009 11:49 am Reply with quote
Its not generally considered a very nice job and my advice to callers is to call the service agent.
However, it may be more cost effective to just replace it and then try to work on the old one to keep as a spare. They are a lot nicer when they have completely dried out!
You should not have a macerator if its the only toilet in the property.
Tony
Back to top
 Alert Moderators
Giblets46
from United Kingdom
PostPosted: Wed Mar 11, 2009 4:02 pm Reply with quote
Thanks for the advice, called in pumpmasters. The macerator is ina downstairs toilet, so it needs something in there! Just hope it can be fixed, as just seen they are 500!
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3490 times
PostPosted: Wed Mar 11, 2009 6:28 pm Reply with quote
You can get them for about 200 under their cheaper brand name, turboflush or something similar.
Tony
Back to top
 Alert Moderators
Giblets46
from United Kingdom
PostPosted: Fri Mar 13, 2009 8:40 am Reply with quote
Edited:
Back to square one, with the outflow pipe blocked, and the macerator apppearing to pump well. Caustic Soda?
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Edited 4 240 Fri Jun 20, 2014 3:18 pm
Edited 24 640 Sat Jul 21, 2007 6:30 pm
Motorised valve different types? Edited 20 1420 Thu Sep 25, 2008 6:36 pm
Edited cylinder question. 6 400 Fri Jan 27, 2006 12:28 pm
Condensing boiler outflow pipe 15 1260 Sun Nov 07, 2010 6:21 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
