Hi all
this is my first post so hopefully I give all the required info (as I know little about plumbing) and someone can assist - if I need to put more information, please let me know
Current system (in top floor flat)
Apollo fanfare SI boiler in kitchen with hot water tank in hallway
British gas CH/HW controller
Electronic control thermostat
Problems - these all seem to be intermittant, but on a regular enough scale to be really annoying
1. The boiler does not always fire. It does not even attempt to spark for ignition - I just seem to get the whirring noise (of the fan I assume). If I notice this and then manually flick the boiler on and then off, it clicks and ignites no problem and will then be fine for the rest of the evening. This can happen in the morning or the evening when its timed to come on - leaving us with no HW or CH
British gas have changed the solenoid, PCB and the fan but it is still doing it - they do not seem to know whats wrong with it!
2. The boiler comes on at random times when both the timer and controller are off
3. The boiler/pipes sometimes make a loud grinding noise - seems to be just before the boiler is stopping its cycle
I have one of these homecare agreements with Brit Gas and have them out a few times, but the engineers seem to change one part, think its fine and then leave. I know the boiler is quite old, but at the moment I cant really afford to get another one.
If anyone could help with these issues it would be really appreciated
