Communal solar hot water
22 Feb 2009
London
Does anyone have any knowledge of solar panels being used on a communal roof with a twin coil cylinder in each flat?
Getting people to contribute to the costs of a scheme with no payback time would be well neigh impossible.
Getting a social housing scheme to pay so much should fail for the same reason!
Better insulation will give the same annual gas savings for far less cost!
Solar may be a good idea but not at current costs.
Tony
Sorry I should have gone into more detail. I'm currently working on a new build 40 flats with twin coil cyl in each flat and panels on roof. Personally I don't think the set up will work. Resol controller in each flat, sensor cables from panels brought down into each flat, pump connection on resol feeding overheat stat > feeding 2 port valve, orange of valve turns communal pump on roof. I think extending the sensor cables will be inaccurate, and the heat loss will be immense over those distances.
I just wondered if anyone on here has installed a similar system.
It could be made to work, but I doubt you have sufficient roof space for the area of collectors needed.
I think theres roughly 100 collectors, they worked it out just over 2 per flat. Also they've installed communal boilers, so I doubt the solar will get a chance to heat the tanks before the boiler does
But there are twin coil cylinders fitted as you state above.
Why would the solar not get a chance to heat up the the portion of the cylinder that it's coil is allocated too?
Because the boilers will be heating the cylinder 24/7 (until stat shuts off) so the majority of the tank will be heated by the boiler, and the recovery time will be so fast the solar won't get a chance
