DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Rcd do not trip at x1
  View previous topic :: View next topic
Author Message
Joe100w
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 06, 2009 2:22 pm    Post Subject:
Reply with quote Thanks
hi,
I am testing a circuit that goes to the garden with armoured cable. The RCD will not trip at x 1 (gets over 400ms) but trips fine on x5. The other circuits seems to be fine with the RCD test (30 mA). Using megger mft 1552. Any reason?
When I move that circuit to the other RCD (30 mA) it trips fine within the time.
My puzzle why will the garden circuit not trip at x 1. What could have been wrong.
Thanks.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ColJack
from United Kingdom
Thanked: 129 times
PostPosted: Mon Apr 06, 2009 2:31 pm    Post Subject:
distance of run? dodgy earth? dodgy neutral?
what are the Zs readings for the garden circuit?
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Mon Apr 06, 2009 4:06 pm    Post Subject:
It is incorrect to test an RCD from a final circuit.
Test it in isolation.
What was the Zs at that point before you started work?
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
Joe100w
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 06, 2009 4:27 pm    Post Subject:
Zs is 1.32, Protected by type B MCB rated at 16A. Wiring all 3 is 2.5 mm and the armoured also is connected to Earth.
Insulation resistance >299 on all three.
Could not get a trip on 1 RCD with several attemps, but same circuit was fine when swapped over to the other RCD
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Mon Apr 06, 2009 4:32 pm    Post Subject:
Test the RCD in isolation. If it fails, swap it out.
__________________
Back to top
 Alert Moderators
Joe100w
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 06, 2009 5:15 pm    Post Subject:
Securespart
Might sound silly, how do I test Rcd in isolation.
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 129 times
PostPosted: Mon Apr 06, 2009 5:26 pm    Post Subject:
take the cables out of it and put the test leads on the load side of it...
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Mon Apr 06, 2009 10:43 pm    Post Subject:
Or if it is difficult to take the cables out of the outgoing terminals, switch off all the MCB's attached to that RCD to isolate the live terminal, then either disconnect all the neutrals from the busbar attached to that RCD or pull out (if it is flexible) the neutral feed to that busbar.
__________________
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
RCD trips on 'no trip test' 6 400 Thu May 15, 2008 6:20 am
lights gone out but trip switch still on 7 1240 Mon Mar 31, 2008 8:00 pm
Electric Shower Trip 6 260 Fri Mar 28, 2008 9:03 am
why does the RCD trip the moment I plug something in? 3 260 Wed May 28, 2008 4:45 pm
Outdoor RCD socket Trip 7 220 Mon Jun 23, 2008 10:30 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
