- Joined
- 5 Jan 2006
- Messages
- 106
- Reaction score
- 0
- Country
Hi all
I had to remove a radiator to decorate a bedroom in my house to remove the woodchip wallpaper from behind it. All was going well, until i took the radiator off and the joint between the thermostat and the floorboards started dripping.
I tried to tighten it up but was unable to, so in order to prevent a leak, I drained the system fitted a JC Speedit end stop onto the pipe having removed the thermostat and then refilled the system.
I have bled all radiators in my house and also bled the pump, but after about 5-10 mins of having the heating on - the boiler starts making a noise. The heating works fine in all radiators but the noise sounds like a saw and is coming from the boiler (not the pump)
I have only left it on making a noise for another 10 mins or so - but have repeated this daily for 3 days.
There are also two vertical sections of pipe with values on the end in the airing cupboard, which i have bled to let the air out of them too.
Any ideas what I can try?
Boiler is Baxi Solo HE
( It isnt a combination boiler and I still have a water tank in the loft)
(having read up a bit more on what i did to prevent my flood, the only thing i can think of that i may have not done "by the book" was that i turned the boiler off from the control panel - and not the mains electric. Is it likely i have damaged the boiler?
Should i leave it on for longer (making noise)?
