DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Connecting downpipe into Cast Iron soil pipe
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering
Author Message
Mr M
from United Kingdom
Thanked: 2 times
PostPosted: Wed Apr 22, 2009 8:18 pm Reply with quote
I originally posted this in the Building section but received no responses so presumeably, it was in the wrong section. I am after some suggestions on the easiest and most cost effective way of dealing with the following:-
The hopper shown in the picture below is taking from left to right; 32mm Bathroom wash hand basin waste, 68mm down pipe from roof and 40mm Bathroom bath waste
this then goes into a 68mm down pipe which does not discharge into a gully but discharges all water at the side of the 4" cast Iron soil pipe into the formed channel. This channel then runs down into a gully which takes the kitchen sink and washing machine wastes
I think with the amount of water which is being discharged, this is having a detrimental effect on the adjacent Kitchen floor which is solid, not timber. The floor is uneven and has a 'hump' in it and the floor tiles are loose and are cracking underfoot. I think the water is saturating the Kitchen subfloor and I therefore need to eliminate it discharging directly onto the floor outside.
Rather than Installing a gully and having to excavate to connect this into the underground drainage system, Is there a way of connecting the 68mm downpipe (below the hopper), into the cast Iron soil pipe. I assume I would need some sort of fitting or adapter to clamp onto the soil pipe and that a hole would need to be formed in it or would the cast iron soil pipe need to be replaced in plastic and then a 'Y' or branch type fitting be Incorporated into this to connect the 68mm downpipe into.
Look forward to your thoughts and suggestions.
Mr M
Back to top
 Alert Moderators
justlead1
from United Kingdom
Thanked: 8 times
PostPosted: Thu Apr 23, 2009 5:13 pm Reply with quote
Hi. Is not that easy. The hopper and 65 mm pipe if connected to soil would omit odour / smell from the soil pipe / drains , which is dangerous to health.
We can purchase strap on bosses for cast iron, which require a hole to be drilled in the soil pipe and then clamped into position, the wastes pipes are then connected (presuming the appliances they serve are trapped?) Good Luck
Back to top
 Alert Moderators
Mw Roofline
from United Kingdom
Thanked: 216 times
PostPosted: Thu Apr 23, 2009 9:35 pm Reply with quote
Like justlead said, are the appliances trapped? It would look a little like spagetti junction but it can be done.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering All times are GMT
Page 1 of 1
Jump to:
Connecting linear drainage gulley to underground drain pipe. 3 1200 Sat Apr 04, 2009 9:29 pm
Connecting three gutters to a water butt 6 140 Sun Jun 19, 2011 6:19 pm
connecting mains to a megaflow system 3 420 Wed Aug 05, 2009 9:24 pm
Connect cast iron soil pipe to clay drain? 6 720 Sun Apr 03, 2011 3:32 pm
Cast iron soil stack through tiled pitched roof -lead flash? 13 1560 Thu Nov 23, 2006 8:40 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
