Hi
I thought this was an easy one to fix, it had to be a leaking stop cock valve. So I replaced the hole unit and alas the water tank is still overflowing! I spent some time watching the water tank filling up from the valve and confirmed that the it was indeed stopping when reaching the correct level. As I was monitoring it I noticed water level still rising even though the valve had shut off.
A closer look showed, I noticed that water was feeding back in from the exit hole from the tank. Bizzare don't understand how it is possible.
The exist hole feeds the Hot water cylinder which is heated by the boiler, I can only think that the hot water cylinder is over filling and pushing back up into the cold water cylinder?
Any Ideas, anyone?
This is my first post so please let me know if you need information. Please see the diagram below which gives you an idea of my system setup.
Many thanks in advance
Any Ideas, anyone?
