Joined: 07 Dec 2004 Posts: 11 Location: United Kingdom Thanked: 0 times
Posted: Tue Dec 07, 2004 1:28 pm Post Subject:
Broken Treads
I have a number of broken treads on my stair case and wondered how easy it is to replace them. I have no access to the underside of the staircase as it is plasterboarded and artexed. Would it be simpler and is it possible to fix another surface on top of the broken boards?
Posted: Tue Dec 07, 2004 4:22 pm Post Subject:
It's not the nose - the treads are broken in the middle right the way from side to side. Some are so bad there are gaps in them. Presently I have just padded them with double layers of underfelt below the carpet but I would like a better finish as this looks bulky and ugly. I am currently putting laminate flooring round most of the house as we have three dogs and a cat and I am fed up of trying to get the hairs out of the carpets especially on the stairs.
Once the treads are sorted is it possible to use laminate on the stairs or would it be too slippy and dangerous?
Posted: Tue Dec 07, 2004 11:23 pm Post Subject:
There is carpet over the stairs at the moment but if I remember correctly some of the risers were pushed back a little. The strings looked OK although I was worried about how safe the stairs are considering the amount of damage to the treads. I am researching this problem now to ensure I have all I need - both knowledge and material wise - before I go ripping up my carpet.
Joined: 05 Jan 2003 Posts: 10853 Location: Essex, United Kingdom Thanked: 7 times
Posted: Wed Dec 08, 2004 9:01 am Post Subject:
MEPEK wrote:
I've looked at the laminate nosing. Thanks. What would you use at the back and sides - ¼ round?
Interesting and I be interested if anybody have done this & give their opinion, doesn't say about using underlayer. I would've thought it will need expansion gap as well maybe ? Could be noisy as with any stairs without carpet but thinking in a term of air squeezing out the sides or springy action maybe ? Be great to hear anyone who has one fitted.
MEPEK,
To be honest you would need to rip out the plasterboards underneath to do a decent repairs, if not then plenty of strong wood glue with thin timber then sanded down plus some strong wood filler.
__________________ Always judge a man by the way he treats someone who is of no use to him
Joined: 12 Jul 2004 Posts: 5771 Location: Surrey, United Kingdom Thanked: 24 times
Posted: Wed Dec 08, 2004 10:10 am Post Subject:
i am just wondering if the wedges have fallen out
what ever it is i would want to investigate properly if the wedges holding the risers are loose fallen out the treads must also be loose to slip back so the stair case may or may not be in a generaly bad condition and possibly becoming unsafe
dont wont to frighten you but i would look at a minimum of the areas under the dammaged treads as masona says "rip it out and start again"wasnt that a song
__________________ big all
we are------------------ all still learning
Posted: Wed Dec 08, 2004 11:27 am Post Subject:
Thanks all.
I always fancied an open staircase to let more light into the hall. If I am ripping out the plasterboard anyway - Is it possible to remove the risers on the existing stair while I am repairing the treads or is it an entirely different staircase construction that is required altogether.
Posted: Wed Dec 08, 2004 12:53 pm Post Subject:
Yes, everything is removable depending how well it's glued and the layout of your staircase, a straight flight of staircase is the easiest to do.
You could remove one of the treads & risers and take it to the joinery shop to have some new one made up or complete the staircase. The most popular timber for staircase tread is parana pine (a nice hint of slight red wood grain) that if you're not going to use carpet again.
If you want to have open riser may be quicker & cheaper for a new staircase instead as the treads are thicker without the risers.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
