- Joined
- 27 Jan 2008
- Messages
- 23,663
- Reaction score
- 2,666
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I have an old simple Glow-worm Space Saver boiler. Until beginning of this last winter it has broken down once in 28 years when the transformer failed. I am more interested in reliability than fuel costs. Beginning of season it sooted up. I tried loads to heating and ventilating people but could not get anyone out. But once I had removed the soot it started to work again. Except about once a week the pilot flame went out. Flame looked OK and re-lit easy enough so changed the thermocouple in case but still the same. Then at long last I found a gas safe registered guy. He looked at it and told me to buy a pilot kit which he would then fit. But before I got one started to fail daily so I looked more careful and realised it only failed while running never when just on pilot so I stripped again and cleaned everything in case it was soot stuck in something causing the problem. Since then pilot flame has not failed.
Now I have a problem. As I said I want a reliable unit. Now it not so cold if I am to do anything now is the time.
1) Is there any point in my still getting this pilot flame kit?
2) Is it likely I have cured the problem or do I still need to do something?
3) If I replaced the hot water boiler which is a Main 7 with a combi boiler can I keep the old reliable glow worm as a back up?
I know if I use a water storage unit I can have multi-sources of heat all running at same time. But that is not what I want. I want to if the modern boiler fails to be able to switch it off and revert back to old faithful.
My family all have gas boilers all more modern than mine and all have failed with complex faults requiring printed circuit board changes etc. My old faithful has no printed circuit board so that can’t fail.
I realise that no one can give a 100% answer on this but some thoughts would be welcome.
One idea would be to install an electric back-up boiler as any break down on an electric boiler I can fix.
Had I found loads of muck in the boiler I would have no worries but I found very little wrong with it. Flame does seem more steady now but not completely steady still a little jumping with small non blue gaps between burner and flame. But before cleaning there were larger gaps between burner and flame and I was under impression it was snuffed out rather than blown out.
I am all ears.
I am all ears.
