We are getting a slight tingle/shock from the hot water not the tap but the water any ideas.
Also gas board came today to check the boiler & engineer said that all our sockets were wired right but had reversed polarity, neutral is pin is now live, live pin is now neutral, so he has rewired the plug to the boiler to this configuration. He said this sometimes happens on older properties (1930 ish).
Any help or explanations would be helpful Thank you.
