The CH and DHW are both working perfectly but the Pressure is sitting at 3.5/4 bar and water periodically comes out of the overflow.
How do I get the pressure down to 1/1.5 where it should be? The most distressing thing is that water is now also dribbling out of the left most pipe into the boiler which appears to go into the pump...? Since everything is working at the moment and there is no warning light on the boiler then I'd like to fix the problem before something major occurs as a result of whatever it is that is causing the over pressure.
Any advice is very much appreciated
