DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Sealing internal brick walls
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
Author Message
ellgee
from United Kingdom
PostPosted: Tue Jun 09, 2009 12:36 pm Reply with quote
Whats the best thing to use to seal internal brick walls?
We're turning our garage into a (part time) games room so need to spruce it up a bit.
Ideally looking for something that dries clear so we can still see the bricks - we won't be painting over it.
Also, would the same thing work on breeze blocks (as one of the walls is built with them).
thanks
Back to top
 Alert Moderators
Zampa
from United Kingdom
Thanked: 26 times
PostPosted: Tue Jun 09, 2009 5:28 pm Reply with quote
You can but a clear brick sealer..water based i think, try b an q
Back to top
 Alert Moderators
Robbie uk
from United Kingdom
Thanked: 168 times
PostPosted: Wed Jun 10, 2009 11:59 am Reply with quote
You could use a clear matt varnish. If the bricks are old bricks that have been cleaned up and you want to bring out their natural colour you can use 50% Turps and 50% raw linseed oil. The turps gives the bricks the natural colour and the oil keeps it that way.
Back to top
 Alert Moderators
Robbie uk
from United Kingdom
Thanked: 168 times
PostPosted: Wed Jun 10, 2009 12:01 pm Reply with quote
Login to view this image
Bit like this...
Back to top
 Alert Moderators
Zampa
from United Kingdom
Thanked: 26 times
PostPosted: Sat Jun 13, 2009 5:17 pm Reply with quote
That looks good..cheers for that Rob..
Back to top
 Alert Moderators
peteftw
from United Kingdom
PostPosted: Sun Jun 14, 2009 8:44 pm Reply with quote
top tip there robbie havnt herd that one before. by turps do you mean actual turps or white spirit?
Back to top
 Alert Moderators
Robbie uk
from United Kingdom
Thanked: 168 times
PostPosted: Sun Jun 14, 2009 10:48 pm Reply with quote
Doesnt really matter which one. Ive done this many times on old brickwork. Brings out the natural colour of the brick. Works best on the old types of bricks.
Back to top
 Alert Moderators
marsaday
from United Kingdom
Thanked: 8 times
PostPosted: Wed May 12, 2010 3:36 pm Reply with quote
hi robbie
I would like to ask a bit more about the turps/linseed oil treatment.
do you mix the 2 up together and then apply or do you treat with turps first and then apply the oil?
Back to top
 Alert Moderators
Robbie uk
from United Kingdom
Thanked: 168 times
PostPosted: Sat May 15, 2010 11:45 am Reply with quote
Mix the two together and then apply liberally with a brush. icon_biggrin.gif
Back to top
The following 2 users say thank you to Robbie uk for this useful post:
grabber (15 Sep 2013), DARTHVILLA (20 Dec 2012)
 Alert Moderators
Hib
from Ireland
Thanked: 2 times
PostPosted: Tue May 18, 2010 3:56 am Reply with quote
Thompson's One Coat Patio and Block Paving Seal
Could be an option, if the job's not already done
http://www.google.co.uk/products?hl=en&q=thompson's+one+coat+patio+%26+block+paving+seal+clear&um=1&ie=UTF-8&ei=jw7yS8yHGIX20gSZ6fGVDQ&sa=X&oi=product_result_group&ct=title&resnum=3&ved=0CDkQrQQwAg
You've probably tried both Rob, so i assume ur way gives a better finish?
Back to top
 Alert Moderators
opps
from United Kingdom
Thanked: 187 times
PostPosted: Tue May 18, 2010 6:50 am Reply with quote
Only asking because I honestly do not know- but what is wrong with plain old diluted pva- cheap/odourless/easy clean up.
Back to top
 Alert Moderators
Hib
from Ireland
Thanked: 2 times
PostPosted: Tue May 18, 2010 12:25 pm Reply with quote
What do you think diluted pva would be like compared to the patio sealer for using instead of the patio sealer (for sealing patios) as a money saver?
Would they be anywhere near the same strength?
I'm genuinely interested/not trying to be funny
Back to top
 Alert Moderators
Robbie uk
from United Kingdom
Thanked: 168 times
PostPosted: Tue May 18, 2010 3:47 pm Reply with quote
Thing is PVA will put a slight shine on the brick work, which is what i didnt want at the time.
Back to top
The following user says thank you to Robbie uk for this useful post:
Hib (20 May 2010)
 Alert Moderators
opps
from United Kingdom
Thanked: 187 times
PostPosted: Tue May 18, 2010 7:27 pm Reply with quote
I wouldn't recommend using pva outside
Back to top
The following user says thank you to opps for this useful post:
Hib (20 May 2010)
 Alert Moderators
Robbie uk
from United Kingdom
Thanked: 168 times
PostPosted: Tue May 18, 2010 7:59 pm Reply with quote
Thought we were talking of inside ??
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Painting brick wall (internal) 2 120 Mon Aug 29, 2011 11:35 am
Plastering directly on to internal brick work 2 140 Sat Jun 01, 2013 11:24 pm
Lime-washing an Internal Brick Wall 2 100 Thu May 09, 2013 12:05 pm
Sealing/staining Oak internal doors 6 2580 Thu May 24, 2007 11:05 pm
Using masonry paint on internal walls 8 3500 Thu Sep 27, 2007 1:55 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
