Which method to lay floor ?
25 Jul 2008
Bristol
Need to lay 50mtrs of solid wood floor at home as quick as pos (no 3 baby due soon :( )
My options are glue to floor or float.
Opinions please :)
lounge 6.6m x 3.3m din room and hall make up rest, its the lounge which i need to do first.
Lounge floor is mostly over timber floor which is in v good condition but last 2mtrs one end are screeded which i have latexed level (ish).
Din room and hall all screed.
Floor to lay is 18mm thick solid oak pre finished, t & g in lengths between 300 to 600mm.
I have already got some floor underlay in panel form but not hell bent on using it.
Cheers
Definitely glue down in rooms with screed/concrete. In lounge you can secret nail or install plywood first and then glue floorboards down
Few more questions :roll:
Can I glue to floorboards with the same glue as screed?
Also can I apply floor without dpm over screed, there are no signs of damp!
And lastly can i use an of the shelve adhesive?
Use a flexible adhesive (like Mapei P990) on screed and on plywood (nailed or screwed onto floorboards)
No need for DPM if you are certain there is no moist problem.
Not sure if the DIY sheds sell the proper quality adhesive, just stay away from anything that mentions bitumen
Before I read your reply I bought bona s760, not flexible! but told it was good???
Offered flexible but was twice the price.
I know you get what you pay for but this stuff cost 60 plus the dreaded for 25kilo pot (yes ive probably had my pants pulled down).
Please tell me its ok for the job (ok is good enough for me) :D :D :D
Thanks again
You're al right ;-) Does fit the bill because your boards are rather short.
Did you buy a proper notched trowel too?
Diamond geezer :wink:
They supplied a metal trowel with the pot which has 4mm Vs every 15mm or so :?:
