Hi all
I think it would be best to start off by saying that my 8 months pregnant wife has had no access to hot water for three days now.
Over the weekend I took out 2 radiators and blanked off the flow and return. (I am going to be putting in underfloor heating). Everything went well until we discovered that the hot water is not working. I bled the radiator upstairs and that seems fine. I turned on the heating too. I then crawled into the loft space and found that the flow pipe from the boiler downstairs to the pump is hot, beyond the pump is hot too. The pump is running and the 3 different speed settings seem to be working fine. Just before the motorised valve (http://www.uk-plumbing.com/brochure/drayton/D42MotorValves.pdf) there is a branch in the pipe which has a valve (I think – it looks like a tap without a handle?). This pipe feeds the return back to the boiler downstairs. This pipe is hot all the way back to the boiler. The pipes to the radiators and the hot water tank are both cold beyond the motorized valve. I have taken the head? of the valve off just leaving the copper connection/valve. I can only rotate the spindle for the valve by about 15 degrees at most with my fingers. Is this correct? On closer examination of the motorized valve head I noticed that a small piece of the internal extension of the override black lever which moves the gear is broken off. I found the broken piece too. Does this suggest that there is something obstructing the valve and the motor drove against this obstruction until this black plastic lever broke?
I would appreciate any help with this. What should I do? Can’t be boiling water on the stove forever!
