Hi there
I recently had to have the inlet valve for my toilet replaced as it was spraying everywhere and this ended up with a leak through the ceiling! Before it was replaced i also noticed that the ballcock arm was pretty much at the top and hence the cistern was full to the brim with water.
I now have a new inlet valve and the ballcock has been adjusted so that the water level is about 1 cm below the line marked on the cistern. Since this has been done though I now have 2 problems:
1) There is sometimes a foul smell coming from the toilet bowl - it is not there all the time. As our bathroom is in the middle of the house we have a long run of horizontal soil pipe running under the floor boards of the next room before dropping vertically into the drain. I am thinking that there is now less water going down the pipe with each toilet flush and therefore not everything is going down the soil pipe so it ends up sitting in the pipe. Would adjusting the ball cock result in a bigger flush? This problem has only occurred since the valve was changed and the cistern has a lower water level.
2) After the inlet valve was fitted I ended up with water hammer on turning off taps, using washing machine etc. Initially I managed to get rid of this by turning off the water supply and draining the highest and lowest point taps. This worked for about a week but the water hammer is now back although the banging noise is not as loud as the first time. Any suggestions on what to do - do I just repeat the process?
Thanks in advance for any help - apologies for the long post but I am not that good at explaining myself!
