DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
shower pump temp
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
dazza87
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jun 29, 2009 3:03 pm    Post Subject:
shower pump temp
Reply with quote Thanks
hi i have fitted shower pump salamander esp75,tanks in roof ,cyclinder on floor near pump .no gas boiler so heating up cylinder with 2 imersion heaters.worked fine but cutting out on temp to the pump(doesnt like 65 degrees)turned the heaters right down but think will still be too hot.salamander do a mixer to drop temp to 55-60 but imagine its a bit steep is there any way i can control imersions with a cyclinder stat.money not really a problem for mixer just curious cheers daz
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Richard C
from United Kingdom
Thanked: 48 times
PostPosted: Mon Jun 29, 2009 3:48 pm    Post Subject:
Haven’t your immersion heaters got temperature adjustment? There is usually a slotted head screw adjuster thingy in the top somewhere. I’ve got solar panels so had to fit a TCV (not a Salamander unit) before our Salamander RHP 75 as the water this time of year can get pretty damn hot; worth installing & regulates the water temp to the whole house perfectly.
__________________
Richard C
Back to top
 Alert Moderators
dazza87
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jun 29, 2009 7:28 pm    Post Subject:
cheers rich as i said i have turned down as far as they will(65i think) and they seem ok now must be boarder line though will see how they go.i have a mixer after shower pump which then feeds 2 showers.nice piece of kit but strange it dont like water temp 65 when thats the norm.just wanted to make sure i wasnt missing easy fix
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 48 times
PostPosted: Mon Jun 29, 2009 10:31 pm    Post Subject:
Salamander’s data sheet specifies & their warranty is dependant on the maximum temperature NEVER exceeding 65 degrees (or internal damage cold occur); which is rather on the hot side. There are some arguments that say 60 is required to guard against legionella but most recommend a maximum 50 degrees & care homes & schools are restricted to 40.5 degrees.
__________________
Richard C
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Temp problem with mixer shower 6 220 Wed Feb 11, 2009 3:59 pm
shower temp Problem 5 140 Tue Feb 10, 2009 5:21 pm
Shower Pressure / Temp Problem 3 540 Tue Sep 27, 2005 2:54 pm
no shower temp control 18 440 Mon Apr 13, 2009 8:09 pm
Fluctuating shower temp 2 180 Mon Mar 23, 2009 12:17 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
