Two pan conectors
16 Jul 2009
Hull
I'm wanting to put 2 pan connectors together to get the required hight to connect on to the toilet. I have heard you aint meant to do this. Is it ok to thou?
you can as they do a sleeve to put in one connector and the other connector into the sleeve.
but it looks a bodge.
What are you asking for Absolution? Can`t you fit a flexi connector?
I can' t no as to do the bend required with a flexi it makes the bit that connects to the 4inch pipe fall in the wall cavity.
If i do that i won ' t be able to get the toilet back to the wall its a ackward situiation cause I'm connecting on to an old cast iron stack.
I havent no sorry its an old cast iron tee I'm goin to connect on to however the cast iron is 3inch I'm hoping that a mulit quick with the fins trimmed on it wil fit in to the tee. I wil then paint this black. Problem is i wil end up comming through at about 4.5inch not the 7.5 require. I wil take a pic tommoro. Dnt suppose you've had any experince with these old 3inch cast stacks and connectin on to them.
any stack 3" or 4" can be a pain if it don't line up etc.
how comes its low 4.5"
