DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Dim lighting and fan
This topic originated from the How to page called Installing a electrical mounting box
Click here to return to the page called Installing a electrical mounting box.
  View previous topic :: View next topic
Author Message
Johnclancey
from United Kingdom
Thanked: 0 times
PostPosted: Fri Dec 31, 2004 12:01 pm    Post Subject:
Reply with quote Thanks
Fitted new halogen lights in bathroom using low voltage and dimmable transformer, the problem is now that fan timer cut off is not working when the lights have been turned off. Help!!!!
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
andy
from United Kingdom
Thanked: 0 times
PostPosted: Fri Dec 31, 2004 12:31 pm    Post Subject:
have u wired the switched live and perm live the wrong way?
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Fri Dec 31, 2004 1:18 pm    Post Subject:
You can't put fans on dimmers - you'll need to add a separate switch for the fan, you can no longer have it controlled by the lights....
Back to top
 Alert Moderators
BobRathbone
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jan 14, 2005 1:18 pm    Post Subject:
John,
Mount a 240V PIR over the bathroom door so it detects anyone walking in. Set the timer on the PIR and turn the daylight sensor off. Fit a fan without a timer and use the PIR to control it.
If the fan is in the zones above or next to the bath or shower it must be a 12 volt SELV fan with a transformer.
iv'e done this in my downstairs toilet and it works a treat.
You must also have a fan isolator or an isolator to isolate the entire bathroom lighting and fan. I use a 20A DP water heater switch mounted above the door outside the bathroom.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Fri Jan 14, 2005 10:26 pm    Post Subject:
What if he doesn't want the fan to come on just because there's someone in the room?
I've got my fan triggered by the shower, because that's when it's needed, but it's not a solution that the average person would implement. I've never been convinced by PIRs, or light-switch control, as the fan will come on unnecessarily so many times. Waste of electricity and waste of fan life.
Humidistat or just a switch for the fan and remembering to turn it on and off is the way to go...
PS - still a bit old to be replying to, Bob...
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
CFL lighting 9 580 Sun Feb 10, 2008 9:53 am
Calculating Design and Estimated for mixed Lighting Circuit 4 1060 Tue Feb 05, 2008 2:35 pm
Lighting circuit not working after earth removed. 7 520 Thu Jan 31, 2008 6:38 pm
Bathroom lighting 6 320 Mon Feb 11, 2008 7:52 pm
Bathroom lighting 3 340 Wed Feb 13, 2008 6:58 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
