DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Cutting toughened glass
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
Author Message
notb665
from United Kingdom
PostPosted: Mon Jan 03, 2005 1:15 am Reply with quote
I have a pane of toughened glass and need a slightly smaller size. I was hoping to use the pane and cut it down.
I couldn't cut it with a glass cutter (this was when I realised it was probably toughened glass, plus it's for a kitchen cabinet).
The window merchant is taking ages to get me the correct match.
I have a diamond bladed electric tile saw I use to cut ceramic tiles.
So I was thinking... would cutting toughened glass with a diamond bladed electric tile saw work? Any other suggestions?
I would wear goggles and gloves etc etc.
Back to top
 Alert Moderators
2scoops0406
from United Kingdom
Thanked: 2 times
PostPosted: Mon Jan 03, 2005 9:53 am Reply with quote
Firstly is it toughened or laminated ? If toughened, then the concensus on the sites I've investigated is that no, you cannot cut it, even with a diamond blade.
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 100 times
PostPosted: Mon Jan 03, 2005 2:42 pm Reply with quote
I'm afraid it's impossible to cut as they are toughen but when breaks they shattered into hazardous pieces, the same as car windscreens. I believe they are heated during the toughening process.
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 916 times
PostPosted: Mon Jan 03, 2005 2:44 pm Reply with quote
tryed it on a laser cutter once
Back to top
 Alert Moderators
2scoops0406
from United Kingdom
Thanked: 2 times
PostPosted: Mon Jan 03, 2005 3:38 pm Reply with quote
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 24 times
PostPosted: Mon Jan 03, 2005 3:55 pm Reply with quote
i thought toughened broke into very small pieces, laminated goes into shards (assuming you "give it some stick")
laminated gals is a sheet of glass, sheet of "plastic" sheet of glass, bit like a sandwhich, only you wouldn't want to eat it
Back to top
 Alert Moderators
2scoops0406
from United Kingdom
Thanked: 2 times
PostPosted: Mon Jan 03, 2005 4:11 pm Reply with quote
Toughened breaks into small non hazardous cubes. Which is why it is used in car glass (non windscreen) and some beer glasses icon_eek.gif. Laminated is used to keep the glass together, yes is glass plastic, glass etc. Designed to stop you flying through the windscrren in an accident. Instead, simply spreads your face over the inside of the screen.
Back to top
 Alert Moderators
TexMex
from United Kingdom
Thanked: 1 time
PostPosted: Mon Jan 03, 2005 7:12 pm Reply with quote
Toughened glass is toughened by cooling quickly. This results in the outer skin setting while the core is still cooling (and contracting). The net result is, the whole pane is being pulled together by the unresolved contraction of the core. Any fracture of the outer skin results in failure of the whole pane.
You can do an interesting experiment by dripping molten glass into water. This gives teardrops of glass with a fine tail. The resultant beads are excedingly tough and will tollerate being bashed with a hammer, but if you just snap the fine tail (which is very delicate), the whole bead explodes. Great fun to hand around at parties. icon_lol.gif
Back to top
 Alert Moderators
chappers
from United Kingdom
Thanked: 30 times
PostPosted: Tue Jan 04, 2005 6:12 pm Reply with quote
Prince Rupert's tears they are called check this out
http://www.museumofglass.org/VHS/video/rupert_drop_demo_bb.html
but be careful folks the glass powders fine enough to breathe in.
In answer to your question it cannot be cut
Back to top
 Alert Moderators
ish303
from United Kingdom
PostPosted: Sun Jun 20, 2010 2:14 pm Reply with quote
Well I wish I had read this post before attempting to cut toughened glass!!!
I was going to cut down a glass shelf for a bathroom and assumed my diamond blade cutter would work as I have tiled a kitchen in glass tiles and had to cut a load of them and did so with no problem with it.
Anyway, a few mm in the cutting the entire thing shattered.
Only problem is I have already drilled the bathroom tiles and fitted the supports.
Anyone know where you can get custom made toughened glass from??
Back to top
 Alert Moderators
freddymercurystwin
from United Kingdom
Thanked: 1055 times
PostPosted: Sun Jun 20, 2010 2:24 pm Reply with quote
Glass supplier will be easiest.
Back to top
 Alert Moderators
ish303
from United Kingdom
PostPosted: Sun Jun 20, 2010 2:41 pm Reply with quote
Any reccomendations?
Back to top
 Alert Moderators
freddymercurystwin
from United Kingdom
Thanked: 1055 times
PostPosted: Sun Jun 20, 2010 2:46 pm Reply with quote
Your nearest one. They're all of a muchness.
Back to top
 Alert Moderators
crank39
from United Kingdom
Thanked: 254 times
PostPosted: Sun Jun 20, 2010 4:18 pm Reply with quote
Just google toughened/polished edge/bevelled/glass shelves in Berkshire icon_wink.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
Toughened Glass Kitemark Position 2 2580 Sun Jan 28, 2007 12:21 pm
Toughened Glass / Building Regulations 3 14520 Fri Apr 04, 2008 8:22 pm
Cutting down a hormann sectional door. 3 60 Sun Oct 30, 2011 3:04 pm
Cutting down a interior door 4 200 Sun Jun 12, 2011 12:48 pm
Cutting wall to install french doors. 2 120 Thu Jan 12, 2012 8:06 am
DIYnot
