Hi to all. Apologies for the post but i have searched this forum lots of times for this and various other things, but can't find the exact answer to my problem.
I want to fit a bathroom extractor fan but position is a nightmare due to a window lintel and a flat roof. My question is, can i fit an inline fan with the inlet on the wall right next to the shower head - sitting on the tiles? I have a mixer shower with a pole coming out from the wall with the shower head screwed on the end if that helps set the scene! Or would i have to fit it above the shower head in the ceiling?
The roof above the shower is a flat roof, so it may be possible but a bit fiddly. i was planning on having the inline fan mounted in the small cupboard behind (with separate door) the bathroom which houses the boiler and the plumbing to the shower unit and from the shower unit to the head. Can i do this? Is it ok to attach the fan unit to the wall or ceiling? All the guides i see says install on a roof joist? I was just going to buy a core drill and put a whole in the same wall as the flue for the combi boiler, so the fan unit would be right next to the outlet.
Also, can i install the wiring myself as it's not in the bathroom? Just an fcu then 3pole fan isolating switch? Can i just connect to the radial circuit which feeds the boiler only which used to feed the immersion heater before i got a combi?
I was going to get this one:
http://www.toolstation.com/shop/Electrical/Fans/100mm+InLine+Shower+Fan+Kit+Timer/d190/sd280/p76429
Sorry for all the questions but the electrician who was round doing other things said he wanted to put in a 12v fan and run the cable from this cupboard to the far wall (Right next to the window) in plastic conduit which would look awful ( I don't mind paying someone to do it i just want to know what i can and can't have so know what to ask for before i get the guy in, he's one of my next door neighbours so i want to know exactly what to ask for!
Thanks very much for any help given and apologies for the countless questions!
Andy
Andy
