DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Grundfoss Selectric UPS 15-50 pump models
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Contax
from United Kingdom
PostPosted: Sun Sep 20, 2009 8:32 pm Reply with quote
My system has a Grundfoss Selectric UPS 15-50 (988123) GB, PC 9549, Class H, TF110 IP42 pump fitted, is the Grundfoss Selectric UPS 15-50x18, Model C No: U517, MK.II, Class F a direct replacement for mine or for a different purpose? I just bought it in tatty box for 5 at car boot today, it's new so bought as a standby just in case. I am addicted to keeping spares for everything maybe because hard to find them out in the sticks.
Am I ok to connect a flex from it to mains just to make sure motor runs although I have no reason to think it won't as seller had a lot of new service items such as this and the way he spoke seemed like he was retiring and clearing out unwanted parts.
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 918 times
PostPosted: Sun Sep 20, 2009 9:01 pm Reply with quote
jeez fella its a pump
yes but dont run it for more that 10 secs as soon as you know it moves turn it off
Back to top
The following user says thank you to kevplumb for this useful post:
Contax (20 Sep 2009)
 Alert Moderators
doitall
from United Kingdom
Thanked: 1536 times
PostPosted: Sun Sep 20, 2009 9:25 pm Reply with quote
Normally the 18 is 180mm against the normal pump which is 130mm icon_wink.gif
Back to top
The following user says thank you to doitall for this useful post:
 Alert Moderators
Contax
from United Kingdom
PostPosted: Sun Sep 20, 2009 9:56 pm Reply with quote
Thanks for warning kevplumb, I just ran it for couple ol 3 sec bursts and spun fine just once heard slight noise as if impeller touched pump body but expect that is due to no water.
Back to top
 Alert Moderators
Contax
from United Kingdom
PostPosted: Sun Sep 20, 2009 10:03 pm Reply with quote
Thanks for reply doitall, it looks identical and I take it the 180mm & 130mm are between input and output flange faces, I measured both pumps and both are 130mm, the flange threads are same diameter also, I think it will do the job fine but always nice to be reasured by someone who knows.
Back to top
 Alert Moderators
kevplumb
Thanked: 918 times
PostPosted: Sun Sep 20, 2009 10:08 pm Reply with quote
press the thanks button he's lagging behind icon_lol.gif icon_lol.gif icon_wink.gif
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3487 times
PostPosted: Sun Sep 20, 2009 10:18 pm Reply with quote
That pump must be years old!
I would guess perhaps 20-30 years!
But they were well made.
If your old one has run for so long then its a very clean system and will probably run a lot longer too !
You might have been better waiting for an energy efficient one and saved running costs.
At the show Mr Wilo was saying pumps have got to be energy efficient next year!
Tony
Back to top
The following user says thank you to Agile for this useful post:
 Alert Moderators
Contax
from United Kingdom
PostPosted: Sun Sep 20, 2009 10:36 pm Reply with quote
I understand the system was fitted in 1995 as Ideal stated that was date on boiler when I bought the property Oct 2004, other than having boiler checked (just clean out soot) twice it has run fine, the valve that switches flow from heating to water acted up once 2 years ago but I took control box off operated it with a spanner a few times put control box back on and OK since, I put it down to limescale as got a lot of it round here. First cental heated bungalow I bought in 1973 had British Gas Guaranteed Warmth system, it was fantastic but pump failed on Christmas Day only 13 months old, maybe that is why I don't trust these things like some do.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3487 times
PostPosted: Mon Sep 21, 2009 10:07 am Reply with quote
If the pump is external to the boiler then there is no reason to expect it was changed when the boiler was replaced !
Tony
Back to top
Contax (21 Sep 2009)
 Alert Moderators
kevplumb
Thanked: 918 times
PostPosted: Mon Sep 21, 2009 10:11 am Reply with quote
might be an idea to get some cleanser in the system Login to view this image
Back to top
 Alert Moderators
Contax
from United Kingdom
PostPosted: Mon Sep 21, 2009 1:19 pm Reply with quote
Hi Agile, it was a full new installation in arround 1995, prior to that it had electric storeage radiators and an immersion heater for water. It works fine but radiator sizes poorly calculated and all pipes hidden behind skirting boards si I dread a leak.
Back to top
 Alert Moderators
Contax
from United Kingdom
PostPosted: Mon Sep 21, 2009 1:30 pm Reply with quote
Hi kevplumb, I have thought of this several times but would hate it to cause a leak as all pipes behind skirting boards (prefer them on skirting board for easy access). I thought it would be best to drain system, refill with a cleanser to flush out sludge and limescale, run for a few days, drain then flush through some clean water then add a protector to water at end. I suffer from disability so as usual things often keep getting put off and thinking I may have to get a heating engineer to do it when I get a fault. I have another valve to replace one that stuck 2 years ago and would change immersion heater for a short one all at same time while it was being drained, a major service, I can only do it in afternoons due to illness do you do an afternoon service?
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3487 times
PostPosted: Mon Sep 21, 2009 9:35 pm Reply with quote
Dont use acid based cleansers then. Sentinel X400 or X800 are non acid types.
If you are registered disabled then Warmfront have a lot of schemes to assist with heating repairs and replacements.
Although I dont agree with the concept, they are not means tested!
Tony
Back to top
 Alert Moderators
Contax
from United Kingdom
PostPosted: Mon Sep 21, 2009 11:42 pm Reply with quote
Hi Agile, To qualify for Warmfront it gives a list of benefits you must be on, does not include incapacity benefit and as I own my property and have savings i can not get any help, I was told I should apply for Disbility Living Allowance when I was interviewed for my Blue Card for parking but I do not believe there should be so many different categories, should be a fixed benefit for each person that has paid into the system, if you have saved you should still get the same and as for free housing, council tax and people with utilities pre payment meters, I won't go into that area as it gets me worked up but thanks for mentioning Warmfront even though I do not qualify.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3487 times
PostPosted: Mon Sep 21, 2009 11:50 pm Reply with quote
Call them and ask! Dont just read about it !
An installer here told us about fitting a FREE boiler under their scheme in a 2M house with a big Merc or similar outside.
All being fitted free because he was registered disabled and its not means tested !
A total waste of public money in my view while more deserving people dont qualify.
I dont know what you are classed as or what classification is required. I only read about it.
Tony
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Sabre Se models 13 720 Thu Aug 06, 2009 9:41 am
Ecoflam minor 1 models and "Burbling" B52 burner 20 4100 Wed Oct 14, 2009 2:28 pm
do plumbers specialise in particular boiler models 10 420 Sat Feb 19, 2011 6:06 pm
Noisy Grundfoss 15-60 Central Heating Pump 12 1060 Sat Sep 18, 2010 9:50 am
Potterton Profile 60e / Grundfoss Pump 7 440 Thu Oct 09, 2008 6:34 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
