DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Stopcock leaks
This topic originated from the How to page called Reseating a tap
Click here to return to the page called Reseating a tap.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
dillon
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jan 16, 2005 9:33 am    Post Subject:
Stopcock leaks
Reply with quote Thanks
When I open the stopcock for my mains water supply the stopcock body leaks but if I try to tighten the nut on the body it restricts the efficiency of the stopcock and the capacity to open and close it. What can I do.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sun Jan 16, 2005 9:44 am    Post Subject:
change the stop cock?
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 400 times
PostPosted: Sun Jan 16, 2005 9:46 am    Post Subject:
__________________
a little thanks
goes a long way
Back to top
 Alert Moderators
dillon
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jan 16, 2005 11:31 am    Post Subject:
Hi Kev forgive the delay I was making my usual Sunday pilgrimage to B&Q. (I need to get a life )Re-packing the stopcock seems a better alternative as the Blue pipe the tap is attatched to only just protrudes from the corner of a concrete floor ( sorry breezer , should have mentioned that )and I wouldn't be positive that I would get the seal I need whilst attatching a new tap. If the worst came to worst I could always go at it with a chisel but first I think I will go for the alternative fix so I'm off to the how to pages.Thanks to both of you for responding to my message.
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 2 times
PostPosted: Sun Jan 16, 2005 11:35 am    Post Subject:
Just try tightening the nut on the spindel as they come loose when you use them and then they leak
__________________
If at first you don't succeed, remove all evidence you ever tried.
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Sun Jan 16, 2005 12:07 pm    Post Subject:
It's routine to loosen the gland nut before turning the shaft then tighten it after to stop it leaking.
Turned one Friday. Wouldn't quite shut off so I turned it tighter - top came off in my hand, with water still dribbling out of the taps. Lead each side of stop cock, all behind the skirting.
Back to top
 Alert Moderators
croydoncorgi
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jan 16, 2005 3:09 pm    Post Subject:
Back to top
 Alert Moderators
ratonnastick
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jan 16, 2005 5:22 pm    Post Subject:
buy a new stopcock then swap the main body on yours providing the seat is ok you have new stopcock
Back to top
 Alert Moderators
brumylad
from United Kingdom
Thanked: 1 time
PostPosted: Sun Jan 16, 2005 10:50 pm    Post Subject:
check out this pipe freezing kit.
The problem is the old main stop tap to this property was seized and despite WD40, undoing the gland nut etc, it refused to budge. No problem I thought, lets turn off the main tap to the property. It's a block of flats and the rising main was at least 40mm pipe, the stop tap was huge. Guess what? it turned a treat but didn't stop the water flow, the washer must have perished.
Ok where's the boundary box for a block of flats? in the middle of the frigin road that's were ! (I checked when the road was clear for a few seconds). So either go to the traffic people at the council or get down to Speedy Hire and get a freeze master electric pipe freezer. At £34 plus vat / day.
The freezer won't freeze moving water so you only get one chance at this plus I was concerned the pipe might burst (well wouldn't you be ?). The £700 box of tricks worked a treat, the two black plastic hoses (covered in white frost) carry refrigerant to the two metal blocks clamped to the copper pipe, it froze it within ten minutes (it says on the box it takes 1 hour for 40mm pipe!). The ice plug held back mains pressure water while I changed the old stop tap (I even had to remove the old nuts and olives on this one). Mercifully after allowing the pipe to thaw the repair was sound, and no, I hadn't thought about what I was going to do if there had been a power cut.
Back to top
 Alert Moderators
shaggy
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jan 16, 2005 11:25 pm    Post Subject:
Nice job brumy, but you've made a right mess of that cushionfloor. icon_eek.gif
Back to top
 Alert Moderators
brumylad
from United Kingdom
Thanked: 1 time
PostPosted: Sun Jan 16, 2005 11:35 pm    Post Subject:
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Mon Jan 17, 2005 9:51 am    Post Subject:
BE CAREFUL!
Undoing the oldun could be v diff and a nightmare if connected to lead pipes. AND the threads have changed sometime or other. If you have a stop cock made in GB with female bsp threads each end you have a better chance that the internal threads will be right.
So I guess we all know what you were doing yesterday, then.
I removed woodwork etc and got mole grips on the shaft, to open it again. Then soldered the top crossbar back on, so they can turn their water Down, at least, if there was a prob with the new plumbing this w/e. Back today with the lead-locks. I'll let you know..!
Oh, and did I ever relate the tale of the gut I met who'd frozen a pipe in a mansion block with rather high pressure. He was too slow. The ice plug shot out of the pipe and went through a stud wall. Yes, "through". And he got wet.
Back to top
 Alert Moderators
brumylad
from United Kingdom
Thanked: 1 time
PostPosted: Mon Jan 17, 2005 10:51 pm    Post Subject:
I'm glad I hadn't read that before the job in the pic. The electric freezer allows you as much time as you need I guess ?
I have the freeze master video somewhere I can't recall them sating there is a time limit.
The pipe I froze is of course 15mm copper.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
New bath..new leaks 5 2420 Sun May 07, 2006 10:13 am
wall hung wc leaks 18 900 Mon Jul 03, 2006 7:50 pm
Heat leaks 14 1780 Sun Apr 16, 2006 7:27 am
Pressure dropping / leaks 5 2340 Sat Dec 31, 2005 8:01 pm
Glow worm swiftflow 80, drain point leaks 2 560 Sat Nov 05, 2005 1:28 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
