DIYnot
Local | Network
   DIYnot > Forums
Local | Network
worcester 24cdi water pressure
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
carolg
from United Kingdom
PostPosted: Sun Oct 11, 2009 10:53 am Reply with quote
i think i need to increase my water pressure. It is just under 1 when cold. I have read instructions but for some reason cannot understand them! anyone got simpler instructions for a female please?
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2182 times
PostPosted: Sun Oct 11, 2009 11:03 am Reply with quote
FAQ even has piccies of it
Back to top
 Alert Moderators
carolg
from United Kingdom
PostPosted: Sun Oct 11, 2009 11:09 am Reply with quote
where do i find it?
Thank you lots!
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 916 times
PostPosted: Sun Oct 11, 2009 11:16 am Reply with quote
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2182 times
PostPosted: Sun Oct 11, 2009 11:25 am Reply with quote
I'll even come and read it to you if that helps.
Back to top
 Alert Moderators
carolg
from United Kingdom
PostPosted: Sun Oct 11, 2009 4:53 pm Reply with quote
thank you for directions! couldn't get the key into the hole, it didn't seem to want to fit! Will have to try other means
Back to top
 Alert Moderators
kevplumb
Thanked: 916 times
PostPosted: Sun Oct 11, 2009 5:10 pm Reply with quote
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2182 times
PostPosted: Sun Oct 11, 2009 5:13 pm Reply with quote
This the only way to top up the pressure unless you drain the system and install a separate universal filling loop.
Like your door key, the filling key must be in the right position, or it will not go in.
A tiny bit of hand cream on the rubber o-ring will make it a lot easier; about 3 pounds of pressure will get the key in.
Back to top
 Alert Moderators
gassafeman
from El Salvador
Thanked: 34 times
PostPosted: Sun Oct 11, 2009 6:03 pm Reply with quote
Hand cream Ben! I love the cut of your jib!
Paul.
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2182 times
PostPosted: Sun Oct 11, 2009 11:08 pm Reply with quote
Paul.
I'm completely serious. I use teflon-, or silicone spray, but I don't expect a householder to have that in the kitchen cupboard.
Drop of handcream on the o-ring will do the job as well.
Back to top
 Alert Moderators
carolg
from United Kingdom
PostPosted: Mon Oct 12, 2009 2:59 pm Reply with quote
think i was being to gentle - will try more force! i was scared of breaking something or causing gas explosion!!!!! icon_redface.gif
Back to top
 Alert Moderators
carolg
from United Kingdom
PostPosted: Mon Oct 12, 2009 3:03 pm Reply with quote
me again! one morequestion - once you have got the key in - is it the knob next to the key you turn or the key itself? icon_redface.gif icon_redface.gif icon_redface.gif icon_redface.gif
Back to top
 Alert Moderators
landyandy
from United Kingdom
Thanked: 60 times
PostPosted: Mon Oct 12, 2009 6:14 pm Reply with quote
It's the knob.
You should be able to hear the water entering your system once its opened. Turn it anticlockwise to let water in.
Andy.
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2182 times
PostPosted: Mon Oct 12, 2009 8:13 pm Reply with quote
Once the key is in, you need to turn it about 40 degrees, to make sure it doesn't pop out.
Then you turn the knob.
Close it gently, it does NOT have to be tight. Pull the key out, and if it keeps dripping, just give it a little bit more; err on the side of caution.
Back to top
 Alert Moderators
carolg
from United Kingdom
PostPosted: Tue Oct 13, 2009 12:30 pm Reply with quote
will give it a go tonight after work!
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Worcester Boiler 24CDi - Hot water pressure lost 8 1740 Fri Oct 22, 2004 8:46 pm
worcester 24CDi - v low water pressure 6 8060 Tue Dec 14, 2004 11:10 am
24cdi rsf worcester water pressure 5 1280 Thu Apr 14, 2005 1:47 pm
Worcester 24CDi combi boiler-Proble with pressure 16 22000 Sun Sep 03, 2006 1:04 pm
WORCESTER 24CDI LOW PRESSURE 27 1240 Mon Jan 19, 2009 2:30 pm
DIYnot
