I would like to change the ancient bulkhead light fitting outside my back door (which has not long since had new wiring and switch fitted when the property was refurbished), to a modern security light so we can see to put the key in the back door lock.
The problem is the cable will have to be extended by a few ccentimetres using a terminal strip and so far as I can see it will be exposed to the elements where it comes out of the wall into the new light.
My question is do I need to use special cable and how do I protect this short run of cable from the elements
